Sand Blasting questions.
JohnDeereJimOhio
PostPosted: Mon Jul 30, 2012 5:20 pm    Post subject: Sand Blasting questions. Reply to specific post Reply with quote
Just bought a pot belly blaster off ebay for 104 bucks seemed like a good deal and used my neighbors once was very effective. Was wondering what i should buy to shoot through it to clean up my tractors before i paint them?
Stephen Newell
PostPosted: Tue Jul 31, 2012 3:26 am    Post subject: Re: Sand Blasting questions. Reply to specific post Reply with quote
I use all purpose sand. The sand has some aggregate too large to use with the sandblaster so I have a wooden box with screen wire on the bottom to sift it. When I sand blast I put down some polyethylene plastic to catch and reuse as much of the sand as possible. I then use the sifter box to clean the used sand.
Morris Krodle
PostPosted: Wed Aug 01, 2012 11:31 am    Post subject: Re: Sand Blasting questions. Reply to specific post Reply with quote
#4 sand is fine enough to pass thru most any small nozzle and does a good job without distorting the metal, if you keep the pressure down to about 110 lbs.
JRSutton
PostPosted: Tue Aug 07, 2012 4:03 pm    Post subject: Re: Sand Blasting questions. Reply to specific post Reply with quote
Tractor supply sells some decent stuff - black diamond. Use the 40/80 stuff to avoid clogging.
Obviously use a good respirator no matter what you use but I'd still be real careful about using regular "sand" - read up on silcosis before you do that, so at least you'll be informed.
Keep in mind too that there's probably worse things in the paint you're removing!
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
