HCooke--stumped
dande man
PostPosted: Sat Dec 08, 2012 7:10 pm    Post subject: HCooke--stumped Reply to specific post Reply with quote
did you get it running if so what was the problem??
HCooke
PostPosted: Sun Dec 09, 2012 5:31 am    Post subject: Re: HCooke--stumped Reply to specific post Reply with quote
Not running yet. So far I have swapped the dist from a running tractor; I have swapped the carb from a running tractor; I have swapped manifolds. I replaced the manifold gaskets. I removed the valve cover gasket and observed the valves moving up and down - looked normal to me. I have hotwired the coil (bypassing the switch and the resistor). I have removed the exhaust pipe. I will run for about 3 sec if you spritz carb cleaner into the throat of the manifold and apply the choke.
Roger in Iowa
PostPosted: Sun Dec 09, 2012 6:35 am    Post subject: Re: HCooke--stumped Reply to specific post Reply with quote
Try another manifold.
Roland (AL)
PostPosted: Sun Dec 09, 2012 1:10 pm    Post subject: Re: HCooke--stumped Reply to specific post Reply with quote
Hook up a temp fuel tank that might solve the problem.
Later Roland (AL)
Ken(Ark)
PostPosted: Sun Dec 09, 2012 1:28 pm    Post subject: Re: HCooke--stumped Reply to specific post Reply with quote
Does it have good suction ? With the elbow pipe off and the palm of your hand over the end of the carburetor , can you feel a strong suction ?
Usually I can keep a motor running with a spray bottle of gas or a can of starting fluid if it is a fuel problem .
If not it is usually spark or timing . The suction would be a good indicator on the timing of the valve opening/closing at the right time .
How about the valve clearance ? Probably not the problem but if they are too tight the compression will not build up enough to explode .
Last thought , burn off the spark plugs . Some times fouled plugs look good but if three are not sparking then it will only run a few seconds .
souNdguy
PostPosted: Mon Dec 10, 2012 7:26 am    Post subject: Re: HCooke--stumped Reply to specific post Reply with quote
comp test?
