JD 70 Diesel e/s conversion
Blksmok
PostPosted: Thu Dec 20, 2012 3:33 pm    Post subject: JD 70 Diesel e/s conversion Reply to specific post Reply with quote
I bought a JD70D that someone had converted to e/s. There's no ID on the starter so I'm not sure if it's 12V or 24V (???) It has two 12V batteries. On the first battery the + post goes to the starter solenoid. The - post on that battery loops over to the + post of the second battery. The - post cable on the second battery also goes the a post (ground???) on the starter. Is this a 24V set-up? It spins the diesel engine pretty fast..but not for a real long time.
Kent Petersen
PostPosted: Thu Dec 20, 2012 3:53 pm    Post subject: Re: JD 70 Diesel e/s conversion Reply to specific post Reply with quote
yes
Blksmok
PostPosted: Thu Dec 20, 2012 5:38 pm    Post subject: Re: JD 70 Diesel e/s conversion Reply to specific post Reply with quote
Follow up question. How do you connect a 12V battery charger to charges the batteries? Thanks!
James Lieb
PostPosted: Thu Dec 20, 2012 6:01 pm    Post subject: Re: JD 70 Diesel e/s conversion Reply to specific post Reply with quote
Are you using your compression release while cranking it over?Mine spins over fairly easy with 1 12 volt battery.
teddy52food
PostPosted: Thu Dec 20, 2012 7:26 pm    Post subject: Re: JD 70 Diesel e/s conversion Reply to specific post Reply with quote
one at a time. + to + & - to - .
