Whats this on my converted alt?
Oaf
PostPosted: Sat Jan 05, 2013 5:43 pm    Post subject: Whats this on my converted alt? Reply to specific post Reply with quote
Hey All,
Anyone know what this doohickey is?
It"s on my 650 that had a 12V conversion forced upon it. The wire comes from the dash and goes into a splitter and is connected by this Radio Shack device. Any ideas if I actually need it?
I"ll see if the photo upload is friendly...
Oaf
PostPosted: Sat Jan 05, 2013 5:46 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
It's the resistor/diode looking thing just above my proctologist glove.
souNdguy
PostPosted: Sat Jan 05, 2013 5:58 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
a resistor..
and?
it should be in between key switch and #1.
with #2 jumped to charge stud.
it's the isolation device that takes the place of a 194 lamp or diode to isolate the vreg in the alt from the ignition.
no high magic here.. Smile
Ultradog MN
PostPosted: Sat Jan 05, 2013 6:10 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
Forced upon it?
I'd say the tractor was lucky.
Or you are.
souNdguy
PostPosted: Sat Jan 05, 2013 6:21 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
one thing i'll say. the alt conversions for the 53-64 machines are clean.. you can hang one on with a commercially available bracket set.. or easilly make your own, and it looks good.. not kludged or grafted. AND you don't sacrifice anything at all.. period... .. like with a 65+ tach drive unit genny.
I actually don't mind an alt on a 53-64... though I do like my stealth 12v conversion on my 950 using a gen from a diesel 01 Smile
Oaf
PostPosted: Sat Jan 05, 2013 6:38 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
Might not be magic to you guys, but that's why I asked.
Is there an inline version of this resistor? This one is already corroded because the alternator and this piece jut outside the hood and was in the elements for years before I bought it.
Oaf
PostPosted: Sat Jan 05, 2013 6:40 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
You don't see all the taped up wire nuts that are scabbed onto the harness. I'd rather have stock 6V and do my own butchery.
souNdguy
PostPosted: Sat Jan 05, 2013 6:46 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
you are looking at the 'inline' version.
inline is just a mounting technique.. :)
you can clean it up and just resolder it to wires and tuck unde the hood.. etc.
souNdguy
PostPosted: Sat Jan 05, 2013 6:47 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
do it!
David G
PostPosted: Sat Jan 05, 2013 6:55 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
I put my diodes in with a crimp connector on each end and cover all of it with heat shrink. It looks pretty good.
Oaf
PostPosted: Sat Jan 05, 2013 7:09 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
To replace it, I just take it to Radio Shack and ask for a new one the same color code, or is there a certain type recommended?
souNdguy
PostPosted: Sat Jan 05, 2013 7:21 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
why replace it.. just re-use it.
you are trying awfully hard to make this very easy issue very very difficult.
it's a resistor.. it don't go bad unless it smokes and burns in two or the legs break off.
clean up and put some crimp connectors on it and re-hook it.
or stick a 194 lamp inline from key to #1
Oaf
PostPosted: Sat Jan 05, 2013 8:32 pm    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
Sounds good. Thanks for the help one and all!
Ultradog MN
PostPosted: Sun Jan 06, 2013 3:15 am    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
Your tractor, your call of course.
How many other 6V machines do you have?
What's in your daily runner, wife's car, lawn tractor, motorcycle, 4 wheeler, snowmobile, boat, RV/camper or hot rod if you have them?
Why would anyone want an oddball 6V machine that can't jump or easily Be jumped by everything else he has?
Oaf
PostPosted: Sun Jan 06, 2013 7:45 am    Post subject: Re: Whats this on my converted alt? Reply to specific post Reply with quote
I ride British motorcycles. 6V pos ground neither thrills me nor scares me. Smile
