no spark problems
trouttman
PostPosted: Tue Jan 15, 2013 7:02 pm    Post subject: no spark problems Reply to specific post Reply with quote
The last few weeks I have seen several posts with people having no spark issues.
In the last 3-4 years I have had 3 different no spark problems with my 47 2n 6 volt + ground.
The most recent was about a month ago. All 3 times I had voltage at the coil and no spark at plugs. nothing was shorted in the dizzy, points ok. but no spark at the plugs.
any wags on what it was .
getting late, I will let you know later.
trouttman
JMOR
PostPosted: Tue Jan 15, 2013 7:16 pm    Post subject: Re: no spark problems Reply to specific post Reply with quote
trouttman wrote:
(quoted from post at 23:02:58 01/15/13) The last few weeks I have seen several posts with people having no spark issues.
trouttman
1) Lack of continuity (corroded/mal-adjusted points, bad/broken connections) or 2) shorts (metallic, failed part/insulator or water).
Bob Purinton
PostPosted: Tue Jan 15, 2013 7:29 pm    Post subject: Re: no spark problems Reply to specific post Reply with quote
Assuming you got the front mount distributor; I'd say, maybe, the spring on the bottom of the coil isn't making good contact with the concave headed brass screw in the distributor.
If you got the chinese almost right aluminum backing plate under your points; trash it and get a regular steel one like the original. I had one in my '48 8N and couldn't get a decent spark until I replaced it.
Use good quality ignition parts. there are numerous posts on here with the item numbers you need for distributor components.
Look through Bruce (VA)'s 75 tips for help.
Good luck.
old
PostPosted: Tue Jan 15, 2013 8:03 pm    Post subject: Re: no spark problems Reply to specific post Reply with quote
Points ok so how do you know that??? Do you look at them and see they looked good or did you open and close them by hand and see and hear spark??? Points can and will look just fine but just because they look good does not mean they are good. Sort of like women they can look good but are a man in drag LOL Yep sick but hey just ask crocodile Dundee
Bruce (VA)
PostPosted: Wed Jan 16, 2013 5:45 am    Post subject: Re: no spark problems Reply to specific post Reply with quote
" nothing was shorted in the dizzy, points ok. "
If that was a factual statement, then the only cause of your problem is the Tractor Gremlin.
That is an evil spirit that invades the tractor every now & then......much like the 'good' spirits such as the Tooth Fairy & Easter Bunny.
You have an intermittent short. There are 10 likely sources of the short.
Before you check anything else, make sure you have the correct voltage at the top of the coil as soon as you get a 'no spark' problem. It should be battery voltage w/ the points open & about half that w/ the points closed.
Assuming that the bushings & advance weights are ok, & that you have correct voltage to the coil, the most common electrical failure (no spark, weak spark) points on the frontmount are:
1. The insulator under the brass concave head screw & where the copper strip attaches. (it’s fiber & will wear out; poke & prod w/ your meter leads to make sure it still works)
2. The pigtail at the bottom of the coil not making contact w/ the concave head brass screw inside the distributor. (With the coil on, the pigtail must firmly contact the brass screw. No contact = no spark.).
3. The copper strip is broken or grounded to the plate. (look very carefully for cracks & breaks)
4. The condenser wire grounding to the plate or side of the distributor.
5. The tab on the bottom of the coil not making contact w/ the brass button on the cap. (With the cap on, the tab must firmly contact the brass button. No contact = no spark.)
6. Incorrect positioning of the spring clip on the plate causing the pigtail to ground. (the open part of the clip goes between 7 & 9 o’clock on the plate. That puts the straight part of the clip opposite of the timing screw at 3 o’clock)
7. Incorrect seating of the coil on the distributor due to a loose bail or no gasket.(the coil must not move at all; if it does, replace the gasket or bail. Or stick some cardboard under the bail).
8. Water/moisture inside the cap due to gasket failure or the absence of a gasket. (the cap AND coil have gaskets)
9. Dirty/corroded/burned/incorrectly gapped or misaligned points.
10. Burned rotor, cracked/carbon tracked cap.
Unless the coil is cracked or shows a dead short, chances are it's fine; square coils rarely fail cold. Pull the distributor & do a continuity check.
First, make sure your meter/light works (don't ask....)
You can change points everyday & it will not fix bad bushings. If you are having trouble w/ points failure, check the shaft. If you detect movement, chances are it needs new bushings.
Inspect the points; if they are pitted or burned, replace them. Next, dress the points by running a piece of card stock or brown paper bag through them. New points sometimes have an anti-corrosive dielectric coating on them & old points can corrode or pick up grease from a dirty feeler gauge or excessive cam lubricant. Make sure the points align correctly. Proper alignment is also critical to longevity. Look at the points when they are closed; both sides should mate evenly. Then, check the gap at .015 on the high point of all 4 cam lobes.
Now, follow these steps:
1. Coil off, cap off, points open. One probe on the brass screw & the other on both sides of the open points. On the side closest to the cam, you should have continuity. Not on the other side! If you do, you will also have continuity everywhere because the points are grounded.
2. Coil off, cap off, points open. One probe on the brass screw & the other anywhere on the body of the distributor. You should have no continuity! Now, rotate the tang on the distributor....as the points open & close, you have continuity (closed) and lose it when they open.
3. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other on the cam side of the open points. You should have continuity!
4. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other anywhere on the body of the distributor. You should have no continuity!
At this point, I just put the distributor, coil & cap all back on the tractor as a unit. The reason I do this is because it is real easy to get the cap or coil mis-aligned trying to put it back together one piece at a time & the result is something gets broken or you get a ‘no spark’ problem.
It's possible to put it back on wrong & break it. Look at the slot on the end of the cam shaft. What ever angle it happens to be, turn the distributor tang to match it. Make sure you can tell the wide side from the narrow side on both the cam & distributor! (close counts) Then place the distributor on the front of the engine, gently push it in place & slowly turn the distributor body until you feel the tang slip into the slot. Rotate the distributor body until the bolt holes line up. Then, hand tighten the two bolts until the distributor body is flush w/ the timing gear cover.
Finally, double check your firing order & plug wires. It’s 1-2-4-3, counterclockwise. It’s very easy to cross 3 & 4.
Post back w/ results & any other questions.
75 Tips
