Hairline cracks in SC block
Zach from TX
PostPosted: Wed Jan 30, 2013 2:54 pm    Post subject: Hairline cracks in SC block Reply to specific post Reply with quote
Started cleaning on the block getting ready to maybe set head on and I found a couple of cracks in the block of my SC. One picture shows a crack from #1 sleeve to head stud to #2 sleeve. Other shows crack from #2 sleeve to hole where pushrods run. Not sure if the cracks show up to good in the pictures. Supposed to get head back from the machine shop tomorrow with two new valves, new exhaust seats, and had a little shaved off to get back to level.
C. Amick
PostPosted: Wed Jan 30, 2013 4:04 pm    Post subject: Re: Hairline cracks in SC block Reply to specific post Reply with quote
Was there any antifreeze in the oil? If not, I doubt that you have a problem with these cracks. Can you put some coolant in the block and check for leaks below in case there are other cracks down lower on the block.
Zach from TX
PostPosted: Wed Jan 30, 2013 4:33 pm    Post subject: Re: Hairline cracks in SC block Reply to specific post Reply with quote
No water in the oil that I could tell.
dboll
Guest
PostPosted: Wed Jan 30, 2013 4:54 pm    Post subject: Re: Hairline cracks in SC block Reply to specific post Reply with quote
no.1 does not concern me, no.2 does
C. Amick
PostPosted: Thu Jan 31, 2013 3:34 pm    Post subject: Re: Hairline cracks in SC block Reply to specific post Reply with quote
The head gasket should seal around the lip of the sleeve to keep any coolant that leaks through the cracks up on top of the block from getting into the cylinders. I usually use copper spray on my head gaskets to get a good seal, but others will tell you not to.
dboll
Guest
PostPosted: Thu Jan 31, 2013 5:58 pm    Post subject: Re: Hairline cracks in SC block Reply to specific post Reply with quote
True,but what's going to keep coolant from seeping into the push rod galley?
