Pistons for stroker M crank
Kenny Chinsey
Guest
PostPosted: Sun Apr 22, 2007 10:23 am    Post subject: Pistons for stroker M crank Reply to specific post Reply with quote
I am needing advice on what piston will work with a 5 3/4 stroked M crank. I will be using stock M rods and looking for 4 1/8 bore size. Any thoughts or ideas would be appreciated.
Thanks
trulyred
Guest
PostPosted: Mon Apr 23, 2007 2:20 pm    Post subject: Re: Pistons for stroker M crank Reply to specific post Reply with quote
I have a set of used M&W AP75 large pin that are 4 1/8 and have been modified for more compression.
turbos10
Guest
PostPosted: Mon Apr 23, 2007 3:16 pm    Post subject: Re: Pistons for stroker M crank Reply to specific post Reply with quote
I had Murphys Motor Service build a set of pistons for my M. They are really nice pieces cut from Arias forging.
ChadS
Guest
PostPosted: Thu Apr 26, 2007 6:45 am    Post subject: Re: Pistons for stroker M crank Reply to specific post Reply with quote
Well, you can get you a set of 450 pistons, and whack off the material to make them clear, you can also drop the wrist pin location down a little, and not have to remove so much off the pistons. Cyl head choice,,, 450 head, or a 8060 gas head clearenced for the bigger domed pistons. Would run good on E85 with some pump gas to tame the E85 down, but, its not 10 dollar a gallon fuel. I have kits made to spec for up to 6.125 for 4-1/8th bore. Chad
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
