More help with an M
Gary north of Spokane
PostPosted: Mon Aug 20, 2007 3:13 pm    Post subject: More help with an M Reply to specific post Reply with quote
Back on the 15th I posted here to get help with my M transmission problems. A few guys were kind enough to post suggestions that were very helpful,(thanks, guys!) but the problem still exists. In frustration I am trying to get some more ideas from this distinguished group. Picture this: in neutral with the engine on. Shift into first with just a little grinding. Drive it around. Push in the clutch to shift back into neutral and a hellacious noise begins and the clutch won't disengage. Riding both the clutch and brake pedals to avoid hitting the dog/car/workshop and finally turning it off. It worked before when I put it in first; why not now? So......tractor club guys come over and we install a new disk, pressure plate, throwout bearing, and return spring. No joy. Split it again and everything seems ok although the new throwout bearing now has 1/8" lateral play. Installed a new bearing from Mother Deere, reassembled it, fired it up and.........you know the rest. Any more ideas with this? I now believe it is in the tranny vrs the clutch but don't know where to start. Thanks again in advance. Anybody wanna buy an M, cheap???????
DaveS
PostPosted: Mon Aug 20, 2007 4:04 pm    Post subject: Re: More help with an M Reply to specific post Reply with quote
I'm assuming you replaced the pilot bearing along with the throwout bearing... If not, it may be locking up and if it does, it will cause the exact problem you are describing.
PostPosted: Mon Aug 20, 2007 10:06 pm    Post subject: Re: More help with an M Reply to specific post Reply with quote
Well, no, Dave. It actually has a pilot bushing. I'm trying to figure out how that would work; is the propeller shaft locked to the flywheel then? i.e. the clutch is separating as it should but the propeller shaft continues to turn anyway????? It makes a lot of sense, actually. I am willing to split the thing again on your advice as these are desperate times. Any clue as how to remove the pilot bushing, my friend? Hopefully then I can go away and not bug you guys. Again, thanks!!!!!!
Dave H
PostPosted: Tue Aug 21, 2007 4:19 am    Post subject: Re: More help with an M Reply to specific post Reply with quote
More theory here
If you have a pilot bushing and the prop shaft has been running in there for decades, it would be unusual for it to be galling and locking up with the prop shaft. Dissimilar metals also.
I don't get it either. If the clutch disengages, the coupling between the engine and tranny is over. I think the noise and disengagement probl sha to be in the clutch. You got free travel?
jCarroll
PostPosted: Tue Aug 21, 2007 6:01 am    Post subject: Re: More help with an M Reply to specific post Reply with quote
I've only been inside a 40 clutch - which has the bearing, not the bushing, so this is theoritical advice.
Deere has good engineering. My first guess is that the bore for the bushing has a counterbore which would let a hook get behind (toward the front of the engine) the bushing and pull it out.
#2 - tap the inside of the bushing to permit threading a rod into the bushing, and use the rod as a slide hammer to extract it.
#3 - drill it big enough so that you go through the wall of the bushing, and then tease the pieces out with a cold chisel. The bushing will drill easier then the flywheel - you won't hurt the flywheel.
