Etching primer
Dustyah
PostPosted: Mon Jan 09, 2017 11:37 am    Post subject: Etching primer Reply to specific post Reply with quote
After I sandblast and get back to bare metal, should I be using etching primer, all cast iron, or just sheet metal, then can I paint directly over the etching primer, or do I need to sand 220-400 before paint, like on engine parts, valve cover, intake oil bath, etc, btw this is a 1953 DC case, thanks Dusty
dr sportster
PostPosted: Mon Jan 09, 2017 1:08 pm    Post subject: Re: Etching primer Reply to specific post Reply with quote
I found that for things like valve covers etc the only thing that works good is etching primer. Scuff it with scotch pads.
Dustyah
PostPosted: Mon Jan 09, 2017 1:28 pm    Post subject: Re: Etching primer Reply to specific post Reply with quote
great idea, green scotch pads, then clean up with air,? Water? And paint over, thanks for the tip. Dusty
David G
PostPosted: Mon Jan 09, 2017 4:20 pm    Post subject: Re: Etching primer Reply to specific post Reply with quote
you have to get oil completely off, I clean in parts washer then keep wiping with lacquer thinner until rags come out clean.
CNKS
PostPosted: Mon Jan 09, 2017 7:00 pm    Post subject: Re: Etching primer Reply to specific post Reply with quote
Etching primer is a duplicate of sand blasting, or sanding. Most of the etching primer used by body shops is probably on new sheet metal when they don't want to sand. Sand or sand blast then use epoxy. Etch usually also needs epoxy.
1175AgriKing
PostPosted: Thu Jan 26, 2017 9:36 pm    Post subject: Re: Etching primer Reply to specific post Reply with quote
the point of etching primer is adherence and preventing corrosion. But not removal of corrosion. Sanding is required prior, at least with the DuPont,PPG products I've used for years. Though DuPont sold out. Also painting over etching primer normally isn't recommended that I'm familiar with. Topcoat over with a primer filler or a sealer and then paint. Some of the newer sealers claim to allow application over factory ecoat without sanding. But I never had the heart to trust it. If bare metal isn't sanded the products I've used in auto body repairs will peel off.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
