New owner of john deere 300 garden tractor
Goto page 1, 2  Next
Popo570
PostPosted: Sat Mar 18, 2017 8:10 pm    Post subject: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
Hi guys I just bought this 300 it runs and
mows great. What was wondering how to put
hitch on back for plow or tiller.can some
one show or tell me how please
504
PostPosted: Sun Mar 19, 2017 3:08 pm    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
Check out Weekendfreedomachines.com More information on JD lawn and garden than you every need to know. Smile
El Toro
PostPosted: Mon Mar 20, 2017 6:32 am    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
Your JD dealer should have a hitch. My old Wards tractor use's a sleeve hitch and I've made adapters so I can use a moldboard plow and a 2 wheel trailer. Hal
El Toro
PostPosted: Mon Mar 20, 2017 6:38 am    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
That plow came with a 2 wheel garden tractor and I still use it with my Wards tractor. Hal
SuperHank
PostPosted: Mon Mar 20, 2017 11:21 am    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
Hate to rain on your parade but I never miss the chance to tell everyone how bad the 130 I bought is. It started falling apart in six months and since I bought it from Home Deposit there was no support. It was a problem. To anyone who asks...Do not buy John Deere lawn and garden products.
Popo570
PostPosted: Mon Mar 20, 2017 11:27 am    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
But I don't see what hitch bolts to on back of tractor the axle?
Bob
PostPosted: Mon Mar 20, 2017 12:15 pm    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
A #33 tiller tiller attaches to the frame with it's own mount. If the tractor doesn't already have one, you'll need to obtain and install a rear PTO kit.
For a plow, you can use a sleeve hitch or a CAT 0 3-point hitch, depending on which way the plow you intend to use is set up.. There's sellers on the 'net with new aftermarket ones, as well as any Used ones that may be around.
Popo570
PostPosted: Mon Mar 20, 2017 12:24 pm    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
So the slave hitch bolts to the frame in the four bolt holes that are there under seat on each side?
Popo570
PostPosted: Mon Mar 20, 2017 12:27 pm    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
So Mr Bob does the sleeve hitch bolt to hitch in four bolt holes on each side?
Bob
PostPosted: Mon Mar 20, 2017 8:12 pm    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
Upper holes have spring-loaded pins that hold the sleeve hitch frame to the tractor frame.
For the lower holes, first you install a bolt on each side with a spacer on it, and the sleeve hitch has slots that slide over those as it's installed on the tractor, before the spring-loaded pins are aligned with their respective holes.
Roger in Iowa
PostPosted: Tue Mar 21, 2017 2:48 pm    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
The 300 is NOT a 130. The 130 is a riding mower. The 300 is a Lawn and Garden TRACTOR.
I have a 1978 300. It is still being used. Wore out one deck. Never been overhauled. Hours, a bunch!
Roger in Iowa
PostPosted: Tue Mar 21, 2017 2:50 pm    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
It doesn't bolt on. It is like a quick hitch. Slips over two bolts with spacers and two spring loaded pins go into holes in the vertical sides of frame.
Brendon-KS
PostPosted: Tue Mar 21, 2017 6:17 pm    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
Most anyone who knows anything about vintage garden tractors would tell you that the Deere 300 was a stout, high-quality machine when it was made 40 years ago and would still be regarded as such today. The green and yellow paint is all it has in common with the consumer-grade, box store 130 lawn mower. To base your opinion of all Deere garden tractors ever made on your experience with the latter is quite narrow-minded.
gab
PostPosted: Tue Mar 21, 2017 7:06 pm    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
Popo bought a good one, you bought department store junk.
El Toro
PostPosted: Wed Mar 22, 2017 11:20 am    Post subject: Re: New owner of john deere 300 garden tractor Reply to specific post Reply with quote
The plow came with a Viking 2 wheel garden tractor. It had a one cylinder engine. They also made a twin cylinder tractor. I think they were all built in MN. Hal
Goto page 1, 2  Next
Page 1 of 2
