Is It Safe to Use Ramps Instead of Jackstands
wsmm
PostPosted: Sun May 14, 2017 9:12 am    Post subject: Is It Safe to Use Ramps Instead of Jackstands Reply to specific post Reply with quote
Is it safe to use ramps to raise a Chevy k1500 to remove and replace the side mount fuel tank instead of Jack Stands?
Thanks,
Bill
Redcow92
PostPosted: Sun May 14, 2017 12:24 pm    Post subject: Re: Is It Safe to Use Ramps Instead of Jackstands Reply to specific post Reply with quote
probably safer than the jack stands...use your floor jack under the tank if it has fuel in it..should work okay.
pcrh
PostPosted: Tue May 16, 2017 5:04 am    Post subject: Re: Is It Safe to Use Ramps Instead of Jackstands Reply to specific post Reply with quote
[quote="wsmm"](reply to post at 10:12:41 05/14/17) [/quote]
Ramps are less work then jack stands and both need solid base on which to stand. Concrete or hard pack parking pad is better than ground. The challenge with these tanks is getting at the fittings on top of the tank since there is very little slack to drop the tank and remove the fuel line and fuel guage line. Remember that these items have not been removed in a long time and will resist being parted.
Post new topic    Yesterday's Tractors Forum Index -> Yesterday's Trucks All times are GMT - 8 Hours
