Cage nuts for 450 and 460
Goto page 1, 2  Next
Hugh McKinney
PostPosted: Fri May 19, 2017 5:09 am    Post subject: Cage nuts for 450 and 460 Reply to specific post Reply with quote
Hello all. I'm in the process of dressing up my 450 and 460, and it's time to start putting things back more like factory, rather than so much baling wire and scotch tape:) So I'm replacing a bunch of the cage nuts that anchor the sheet metal in place, they are threaded for 5/16th inch coarse thread bolts. Caseih sells them, for about 10 bucks apiece plus shipping (ouch!), but Fastenal only wants about a buck fifty. Problem is, you have to order a box of 50! Anybody else have any luck finding these cage nuts for a reasonable price? I only need about 10 of them. Thanks, Hugh.
ih560
PostPosted: Fri May 19, 2017 5:20 am    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
Minimum order of 6 but the price is right at $.35 a piece.
https://www.huyett.com/Products/Fasteners/Engineered-Fasteners/Self-Retaining-Threaded-Nuts/EFCN-D07953-5618-4-B?gclid=CjwKEAjwr_rIBRDJzq-Z-LC_2HgSJADoL57HJ2uaCWjOtFHPprJHBjhY6KwyguVC8-KKb8ehKXgYsBoC3ZPw_wcB
Hugh McKinney
PostPosted: Fri May 19, 2017 5:49 am    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
Thanks, ih560, this is the kind of break I
have been looking for, I'm ordering them as
soon as I post this! Hugh
DonO-MN
PostPosted: Fri May 19, 2017 7:42 am    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
The original cage nuts have four wings. I have only been able to find replacement cage nuts with two wings. Anybody ever find a source for replacement four wing cage nuts???
ih560
PostPosted: Fri May 19, 2017 7:55 am    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
I have seen them but they required to be "crimped" into place.
FarmerHR
PostPosted: Fri May 19, 2017 8:34 am    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
Sounds like you are all set. However: if something does not work out, try Mc Master Carr Supply. I think you find them on the internet.
Thanks
pete 23
PostPosted: Fri May 19, 2017 9:36 am    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
Those tractors used more than one style of cage nuts. Some were four corner retainer tabs that had to be crimped in place. Other was the two springy retainers BUT, they also came in different retainers for thick or thing metal they were hooked into. The farmall 400 used fine threaded nuts for all hoods, but course threaded up on the dash. Then some where along the 450, all went to course thread. Lots of cross threaded nuts in wrong places over the years. Fought enough of those hoods for years.
Hugh McKinney
PostPosted: Fri May 19, 2017 4:54 pm    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
I really appreciate all the knowledgeable advice. I wondered if they hadn't made some changes to them, and it's good to find out now before I order parts:)
Dblair
PostPosted: Fri May 19, 2017 6:48 pm    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
they have a bunch at Lowes , I use some on my 450
wolfman
PostPosted: Fri May 19, 2017 6:51 pm    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
Check e-bay item # 381870221335 or # 361445730666 or just google Hood Bolts.
300guy
PostPosted: Fri May 19, 2017 7:00 pm    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
Call Pilot Knob at 815-777-0826. He has them at a great price and he also has a nylon washer to go under the screw to replace the star washers. These prevent the star washer from ruining the paint for the 450. He also has the other stuff for the 560. My last catalog has the cage nuts for $1.20 and the screws zinc coated for .70.
Hugh McKinney
PostPosted: Sat May 20, 2017 1:45 pm    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
Thank you, I'm glad to know I can get the nylon washers too.
D beatty
PostPosted: Sun May 21, 2017 4:11 am    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
I re used most of the cage nuts on my 450 and the one I needed to replace I got from Fastenal.You don't have to buy in bulk at Fastenal you can order any number of cage nuts you want.I did away with the philips screws and used stainless steel bolts with stainless steel flat washers so not to scratch paint. I don't like philips headed screws as with age they become hard to get out. I used the stainless steel in both my Farmall 450 and AC WD45.
Hugh McKinney
PostPosted: Sun May 21, 2017 5:49 am    Post subject: Re: Cage nuts for 450 and 460 Reply to specific post Reply with quote
Thanks for the info, the guy I talked to at Fastenal was apparently "shooting from the hip" when he told me I had to order a minimum 50 of them. Now I can get my machine back together without breaking my piggy bank! Hugh
Goto page 1, 2  Next
Page 1 of 2
