Roof top sewer vent frosts shut
Roger in Iowa
PostPosted: Mon Jan 01, 2018 7:49 am    Post subject: Roof top sewer vent frosts shut Reply to specific post Reply with quote
Anyone use heat tape to keep roof top sewer vent from frosting closed? The vent pipe is 4" plastic.
It is only 20 degrees F below this morning! This is in Ottumwa Iowa. Wind chill is -38.
jon f mn
PostPosted: Mon Jan 01, 2018 7:59 am    Post subject: Re: Roof top sewer vent frosts shut Reply to specific post Reply with quote
Put a larger and slightly taller pipe over it with screws run through it til they clamp it to the smaller pipe, similar to how a christmas tree stand works.
View user's profile AIM Address
moresmoke
PostPosted: Mon Jan 01, 2018 8:06 am    Post subject: Re: Roof top sewer vent frosts shut Reply to specific post Reply with quote
A length of copper tube, 3/4 or 1" with a tee and 2 side legs to keep it from dropping in. Set it in the vent pipe and the copper will draw enough heat up to keep it open.
grizz02
PostPosted: Mon Jan 01, 2018 9:04 am    Post subject: Re: Roof top sewer vent frosts shut Reply to specific post Reply with quote
No but say hi to walter O'Rielly
Stephen Newell
PostPosted: Mon Jan 01, 2018 5:56 pm    Post subject: Re: Roof top sewer vent frosts shut Reply to specific post Reply with quote
When it warms up enough to deal with it you might put a cap on it.
rustyfarmall
PostPosted: Tue Jan 02, 2018 5:36 am    Post subject: Re: Roof top sewer vent frosts shut Reply to specific post Reply with quote
I imagine the problem is from the warm, moist air going up the vent pipe, and then when it hits that -20 stuff, naturally it freezes. I think that a heat tape would fix the problem just fine.
DoubleO7
PostPosted: Tue Jan 02, 2018 7:49 am    Post subject: Re: Roof top sewer vent frosts shut Reply to specific post Reply with quote
Do the copper tube thing as suggested.
Make the tee at top wide enough that it will not fall into the vent no matter what.
Make the vertical leg down as long as possible.
The warm air down there will migrate into the copper itself and stay in longer and migrate to cold. But not so much as to cool off and freeze like the vent pipe exposed to the weather so much.
Calvin Innes
PostPosted: Wed Jan 03, 2018 4:59 am    Post subject: Re: Roof top sewer vent frosts shut Reply to specific post Reply with quote
Here in Maine, Locally at least, we have been painting them flat black and the sunshine does the rest. Works pretty darn good! Also, keep the snow shoveled away from around it.
My 2 cents.
Wyotex
PostPosted: Thu Jan 04, 2018 2:02 pm    Post subject: Re: Roof top sewer vent frosts shut Reply to specific post Reply with quote
I had that problem once when I lived in Wyoming. Mine was a 2" pvc sewer vent. Eventually found the pipe broke behind the wall letting warm air into the pipe.
