D17 series 1 block heater
Luke470
PostPosted: Sun Feb 04, 2018 11:33 am    Post subject: D17 series 1 block heater Reply to specific post Reply with quote
Is there a place on an early D17 series one
to install a block heater?
If so what size?
Thanks!
Aaron SEIA
PostPosted: Sun Feb 04, 2018 12:52 pm    Post subject: Re: D17 series 1 block heater Reply to specific post Reply with quote
I don't think so. You could check on a lower radiator hose one.
AaronSEIA
DrAllis
PostPosted: Sun Feb 04, 2018 2:10 pm    Post subject: Re: D17 series 1 block heater Reply to specific post Reply with quote
Tank type heater using the block drain to feed it and cut the bypass hose in two and install a TEE for the hot water to go into. Either that or a lower hose heater. This is for a gas engine.
JMS/.MN
PostPosted: Mon Feb 05, 2018 1:03 pm    Post subject: Re: D17 series 1 block heater Reply to specific post Reply with quote
Size depends on how long you care to wait to get it warm. Tank heaters typically come in 750/1000/1500 watt size.
Brian in MO
PostPosted: Sat Feb 24, 2018 10:17 am    Post subject: Re: D17 series 1 block heater Reply to specific post Reply with quote
I was in a salvage yard last week and saw a d17 that had a block heater. They had used the block drain then went up to the temperature sensor where they put a tee in to use for a return line.
DrAllis
PostPosted: Sat Feb 24, 2018 3:40 pm    Post subject: Re: D17 series 1 block heater Reply to specific post Reply with quote
CVPost-Brian in MO wrote:
(quoted from post at 11:17:23 02/24/1Cool I was in a salvage yard last week and saw a d17 that had a block heater. They had used the block drain then went up to the temperature sensor where they put a tee in to use for a return line.
***** That is the wrong way to do it, because now the temp sensor bulb isn't in hot water. The temp gauge will always read LOW when installed like that.
