Long 445 popping
shortcircuit73
PostPosted: Tue Mar 06, 2018 9:33 pm    Post subject: Long 445 popping Reply to specific post Reply with quote
I am looking to purchase a Long 445 tractor.
When I tried it out, I noticed, when I started moving, a popping noise in the left rear wheel. It seemed to only do it when I first take off. It also does it when I shifted to reverse and let out on the clutch. It would make the noise just when taking off. It didn't seem to make the noise while driving.
Any ideas? Lose wheel bad gear in the left wheel?
Thank you
Traditional Farmer
PostPosted: Tue Mar 06, 2018 10:05 pm    Post subject: Re: Long 445 popping Reply to specific post Reply with quote
Could be a wheel lugs or bolts where the center bolts to the rim,easy enough to check those out.Also there might be a bearing in the final drive going bad or the final drive might
not have oil in it and is running dry.
vapet
PostPosted: Wed Mar 07, 2018 10:57 am    Post subject: Re: Long 445 popping Reply to specific post Reply with quote
Ran into that on a Fiat Oliver, don't recall the size was a 3 cylinder one. Anyway, finally found slack in spider and axle gears, replaced thrust washers and all was well.
shortcircuit73
PostPosted: Thu Mar 08, 2018 8:48 am    Post subject: Re: Long 445 popping Reply to specific post Reply with quote
shortcircuit73 wrote:
(quoted from post at 01:33:36 03/07/1Cool I am looking to purchase a Long 445 tractor.
Thank you
Thank you for the info. If it is in the gears, is this a hard and expensive fix? I can get the tractor for $2k the engine sounds strong.
vapet
PostPosted: Fri Mar 09, 2018 10:08 am    Post subject: Re: Long 445 popping Reply to specific post Reply with quote
Of course the cost would depend on the problem, and if you could find used parts. I sure would do some troubleshooting before tearing into it. Jack up the rear of tractor and see if there is any free motion and go from there. All wheel bolts tight? Wish I could pinpoint problem for you, but you will have to search it out.
shortcircuit73
PostPosted: Fri Mar 09, 2018 6:59 pm    Post subject: Re: Long 445 popping Reply to specific post Reply with quote
CVPost-vapet wrote:
(quoted from post at 14:08:45 03/09/1Cool Of course the cost would depend on the problem, and if you could find used parts. I sure would do some troubleshooting before tearing into it. Jack up the rear of tractor and see if there is any free motion and go from there. All wheel bolts tight? Wish I could pinpoint problem for you, but you will have to search it out.
Thank you!
Post new topic    Yesterday's Tractors Forum Index -> Lesser Known Classics All times are GMT - 8 Hours
