engine #
BHpony
PostPosted: Tue Mar 13, 2018 7:04 am    Post subject: engine # Reply to specific post Reply with quote
I don't have a serial # plate on farmall H, so where is engine #. The head has been replaced.
Janicholson
PostPosted: Tue Mar 13, 2018 8:26 am    Post subject: Re: engine # Reply to specific post Reply with quote
Above #1 spark plug on a flat casing boss. Jim
BHpony
PostPosted: Tue Mar 13, 2018 10:54 am    Post subject: Re: engine # Reply to specific post Reply with quote
Since the head has been replaced , I guess no way to tell what year. thanks.
Janicholson
PostPosted: Tue Mar 13, 2018 11:53 am    Post subject: Re: engine # Reply to specific post Reply with quote
The casting (block) will have a sequence of numbers on it like 2*18*P (the asterisks are screw heads) these are month Day year as code letter. 1950 is T. Jim
Owen Aaland
PostPosted: Tue Mar 13, 2018 12:27 pm    Post subject: Re: engine # Reply to specific post Reply with quote
CVPost-Janicholson wrote:
(quoted from post at 15:53:12 03/13/1Cool The casting (block) will have a sequence of numbers on it like 2*18*P (the asterisks are screw heads) these are month Day year as code letter. 1950 is T. Jim
The engine serial number is just below the head on the front right side of the block. On the H the chassis serial number and the engine serial number should match.
D Slater
PostPosted: Tue Mar 13, 2018 1:41 pm    Post subject: Re: engine # Reply to specific post Reply with quote
If you don't see the number look for the long tin cover on spark plug side of block. Then notice where the vent tube comes out of the cover it will have a bulge in cover. Right above the cover will be a raised flat spot down below the third spark plug from front of tractor. Had H tractors with engine serial number there and still have one with the number located there. Engine serial number will be the same year as tractor serial number lists for most originals unless a mess up happened or a early block failure.
John M
PostPosted: Tue Mar 13, 2018 4:24 pm    Post subject: Re: engine # Reply to specific post Reply with quote
BELOW #1 spark plug.
D Slater
PostPosted: Tue Mar 13, 2018 6:14 pm    Post subject: Re: engine # Reply to specific post Reply with quote
Serial number not on head. Location on a block casting 6695 DE.
D Slater
PostPosted: Wed Mar 14, 2018 4:20 am    Post subject: Re: engine # Reply to specific post Reply with quote
This block has the flat spot below the number one spark plug like was posted. Some blocks have them at front with no flat on back and some have flat on back with none at front and some have a flat both places.
