Ford 2n Trans Hydraulic fluid
RichieWis
PostPosted: Tue Apr 17, 2018 7:57 am    Post subject: Ford 2n Trans Hydraulic fluid Reply to specific post Reply with quote
I have a 1942 Ford 2n 6volt Front mount w/Sherman Lo-range trans. Removed bottom bolt on the inspection plate and checked dipstick and fluid was very low if any at all. Started adding slowly about 6 quarts. Fluid slowly showing on dipstick, got close to full mark but nothing from inspection hole. Added one more qt and next morning checked it and probably that last quart is on the floor coming from the center cotter pin but nothing from the inspection plate.Started it up and checked everything seems to work fine. Any advise is appreciated! Thanks. I do have F04 manual.
TheOldHokie
PostPosted: Tue Apr 17, 2018 8:22 am    Post subject: Re: Ford 2n Trans Hydraulic fluid Reply to specific post Reply with quote
CVPost-richiewis wrote:
(quoted from post at 11:57:05 04/17/1Cool I have a 1942 Ford 2n 6volt Front mount w/Sherman Lo-range trans. Removed bottom bolt on the inspection plate and checked dipstick and fluid was very low if any at all. Started adding slowly about 6 quarts. Fluid slowly showing on dipstick, got close to full mark but nothing from inspection hole. Added one more qt and next morning checked it and probably that last quart is on the floor coming from the center cotter pin but nothing from the inspection plate.Started it up and checked everything seems to work fine. Any advise is appreciated! Thanks. I do have F04 manual.
What does the dipstick show now?
TOH
RichieWis
PostPosted: Tue Apr 17, 2018 10:49 am    Post subject: Re: Ford 2n Trans Hydraulic fluid Reply to specific post Reply with quote
Dipstick shows about 1/4" above the full line
TheOldHokie
PostPosted: Tue Apr 17, 2018 12:23 pm    Post subject: Re: Ford 2n Trans Hydraulic fluid Reply to specific post Reply with quote
(quoted from post at 14:49:44 04/17/1Cool Dipstick shows about 1/4" above the full line
Then I'd say you overfilled it initially and you should be good to go.
TOH
RichieWis
PostPosted: Tue Apr 17, 2018 12:37 pm    Post subject: Re: Ford 2n Trans Hydraulic fluid Reply to specific post Reply with quote
Sounds good TOH, thanks for the help!
