Engine Trouble
Goto page 1, 2  Next
CK MO
PostPosted: Thu Apr 19, 2018 5:47 pm    Post subject: Engine Trouble Reply to specific post Reply with quote
Working on a MF 165, Perkins gas engine, starts up fine and after about a minute it starts fluttering, when I pull off the number 2 plug wire it seems not to change anything. Seem to have a good fuel supply, have rebuilt one carb and switched out to another, changed the points, cap, rotor, and plugs and moved plugs and the wires and it doesn't move the problem. Today pulled valve cover and checked the rocker arms and valve train all seems fine, compression on that cylinder is down about 8-10 psi from the other 3 cylinders and the plug on that cylinder was fouled badly prior to changing the plugs as if that cylinder has not been firing for some time. Bought at an auction so no history at all. Has me scratching my head, any ideas would be greatly appreciated.
Thank You
CK
jeffcat
PostPosted: Thu Apr 19, 2018 5:51 pm    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
The question you will soon be getting. What sparkplugs do you have. Forget Champion. Someone will give you the number for Autolte plugs. Would be my guess.
Dieseltech
PostPosted: Thu Apr 19, 2018 6:14 pm    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
Did you put in new hotter plugs I recommended on the MF site?
rustred
PostPosted: Thu Apr 19, 2018 6:58 pm    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
never saw a sparkplug brand solve a problem.lol. so... what is the compression test of all cyl's.?? everyone is scared to post actual results , never hardly ever see a post and the guy says yes i checked compression and it is... .that is the most important step to do and post. do you have good fire going to the plug? how was compression test done? need 5 puff's per cyl. and will see the first 2 puffs pretty well top out. everyone is gung hoe on wot but as long as throttle is off idle its not going to make one iota of a difference.
Bruce(OR)
PostPosted: Thu Apr 19, 2018 7:34 pm    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
Champion typically runs a heat range colder than most. Running a colder range does tend to lend to fouling out. If your running an old Chrysler product, pre '80, then Champ plugs are the best. I have spun in a few thousand plugs and that is just what I have found.
47fivewindow
PostPosted: Thu Apr 19, 2018 7:57 pm    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
Run a jumper wire from the battery to the coil + if neg ground. Sometimes resistance in the switch or the wiring will cause a voltage drop to the coil as it gets hot. It seems one cylinder is always the first to quit as feed voltage lowers. Double check the rotor direction and firing order. If you can get a dwell meter see if it is stable, maybe a worn bushing or lobe in dist.
View user's profile AIM Address
kevinstuff
PostPosted: Thu Apr 19, 2018 8:29 pm    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
Leaking head gasket on #2 ?
Is the plug oil fouled? Or is the
plug getting wet from antifreeze?
Or is the engine carbonedb
CK MO
PostPosted: Fri Apr 20, 2018 3:28 am    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
The original plug was fouled with what would appear to be an oily substance, the new plug comes out clean each time.
Thanks for the help
CK MO
PostPosted: Fri Apr 20, 2018 3:33 am    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
I have tried it with a jumper wire from the battery to coil and no difference, tried a different coil, and after replacing points and condenser with no change I put on a new electronic ign kit with the same result.
Thanks for the help
CK MO
PostPosted: Fri Apr 20, 2018 3:38 am    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
The compression test was done with the throttle wide open, choke open and even took off the air filter hose. Results were 1. 146, 2. 135,
3. 145, 4. 144. The motor had been run the day prior but I did not put any oil in the cylinders.
Thanks
Keith Molden
PostPosted: Fri Apr 20, 2018 3:39 am    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
I see all the other replies and am wondering, you've checked a lot of things but no one has said anything about the plug wires. Just a thought, Keith
CK MO
I will try this on the next trip.
Thanks
CK MO
PostPosted: Fri Apr 20, 2018 3:44 am    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
I have not changed them out as they appear to be recently replace and in very good shape, but have changed 2-3 trying to move the miss and there is no change, number 2 cylinder acts like it stops getting fuel/air
Thanks
UncleTom
PostPosted: Fri Apr 20, 2018 3:50 am    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
Make sure the plug is not fouled. It shouldnt be black in color. Maybe a vacuum leak on the #2 manifold?
BarnyardEngineering
PostPosted: Fri Apr 20, 2018 4:25 am    Post subject: Re: Engine Trouble Reply to specific post Reply with quote
Burned valve.
They act just like you said. Runs fine at first, then after a couple of minutes, the cylinder stops firing. By the time you get the compression tester on it, it's cooled down and tests fine.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Talk All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
