What brand is this plow?
Royse
PostPosted: Tue May 15, 2018 6:47 pm    Post subject: What brand is this plow? Reply to specific post Reply with quote
Wondering if wear parts are available.
connor9988
PostPosted: Tue May 15, 2018 6:54 pm    Post subject: Re: What brand is this plow? Reply to specific post Reply with quote
That is a butchered plow. Looks like it might have started off life as a pull type Case plow. You would be better off buying a newer and not cut/welded/broken plow if you plan on doing much plowing.
Royse
PostPosted: Tue May 15, 2018 7:07 pm    Post subject: Re: What brand is this plow? Reply to specific post Reply with quote
Thanks Connor, it would only be used for a garden but if we can't
get wear parts if/when needed then a good deal isn't a good deal.
SVcummins
PostPosted: Tue May 15, 2018 7:18 pm    Post subject: Re: What brand is this plow? Reply to specific post Reply with quote
For a garden you?ll probably never wear the thing out . It is
definitely custom built might be interesting to get it to plow
right
connor9988
PostPosted: Tue May 15, 2018 7:49 pm    Post subject: Re: What brand is this plow? Reply to specific post Reply with quote
Check the back of the moldboards. If it is Case it will have "CX" stamped into it with a number next to it. The number is the spacing of the bottom and the CX will indicate that it is the older style bottoms
which it clearly is in the pictures.
Traditional Farmer
PostPosted: Wed May 16, 2018 7:08 am    Post subject: Re: What brand is this plow? Reply to specific post Reply with quote
Looks like a Hobbled Brand to me.
SVcummins
PostPosted: Wed May 16, 2018 6:47 pm    Post subject: Re: What brand is this plow? Reply to specific post Reply with quote
Wonder what the clevises are welded on there for?
