Pulling out dead trees
Goto page Previous  1, 2, 3  Next
circus
PostPosted: Wed May 16, 2018 4:31 am    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
A neighbor died that way. Charge failed to go off til he investigated.
Davidj
PostPosted: Wed May 16, 2018 5:02 am    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
CVPost-gtractorfan wrote:
(quoted from post at 17:54:00 05/15/1Cool We have large dead ash trees I wish were down in the woods. I don't like being under them when they're already dropped limbs. Wish there was a safe way to drop them.
Tree service.
old
PostPosted: Wed May 16, 2018 7:38 am    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
Many years ago I was hired to do some dozier work for a guy. At the time I had a TD6 that I used. He had cut down a big tree and then wanted the stump pushed out. It took me well over an hour to remove the stump and I had to dig around it till I had pretty cut most of the roots. It was the last thing I was doing on that day. Pushed it out and then parked the TD6 behind the stump. All you could se of the TD^ was the exhaust pipe and the fuel cap the rest was hidden by the stump
ss55
PostPosted: Wed May 16, 2018 9:29 am    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
Digging out tree roots is much easier when the soil is damp or even muddy. The tree pulls over easier in those conditions too. If the soil is dry, haul some water to soak the area where you will be digging.
bishopNlouisiana
PostPosted: Wed May 16, 2018 9:30 am    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
Down here in South Louisiana, I cut the tree about three feet above the ground, let it die if not already dead.
The extra height gives me more leverage when prying the rest. Chain on top pull with tractor. Pull opposite way next and keep changing directions to break the lower roots.
If I cut it close to the ground there is nothing else I can do but wait or chipper.
The hardest stump I ever pulled out was a Black Cherry tree. I tried pulling and burning. I ended up digging out the big roots cutting them with a chain saw and dragging out the stump with the 8N to the fire pit and three years and many, many, fires later you could still see part of the black cherry stump.
I have a 6V 1952 8N and it still does the jobs for me.
circus
PostPosted: Wed May 16, 2018 4:49 pm    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
quoting gtractorfan: Wish there was a safe way to drop them.
quoting Russ: Chain saw? The longer you wait the more dangerous they get!
Yea, dropping them with a chainsaw for safety wouldn't be too difficult (famous last words). I don't want to mow around stumps for the next ten years.
ed will
PostPosted: Wed May 16, 2018 6:48 pm    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
Hi, I have never been beat by a stump. I have a Cat 416 backhoe. Most trees are fairly easy but I've dug out fir trees that have a tap root. It's hard to break that root straight down. But eventually you get it. Ed Will Oliver BC
guido
PostPosted: Wed May 16, 2018 7:43 pm    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
Hello circus,
I would use a strap. Here is a way!
GUIDO.
Charles in Aus.
PostPosted: Wed May 16, 2018 8:25 pm    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
Times two on burning them out .
I use a 44 gallon drum with an old stove pipe chimney attached . No bottom to the drum , place it on the stump and fill the top with small brush wood to get it going . The drum has a door cut into the side to aid updraught . Takes about two days for the biggest gum stump to burn away to nothing , roots and all .
BUT , be careful because the fire will follow the roots for their entire length , under a building as well if that's where they are growing .
Ian Beale
PostPosted: Wed May 16, 2018 9:36 pm    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
Saltpetre - mentioned here
https://en.wikipedia.org/wiki/Potassium_nitrate#Other_uses
IIRC can also be soaked into holes bored in the stump to help burning
JLeus
PostPosted: Thu May 17, 2018 3:04 am    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
I had about a 1/4 acre of honey locust on a property I bought that had been left to become a thicket. I tried everything I had tools to try with, fire worked so so, it was evident my back and my little 641 wasn't enough. I found a used Bluebird brand stand behind stump grinder.........the absolute best $1800 I have ever spent. It didn't take long that of all my tools that one was absolutely NOT for hire or loan. It is mission critical to keeping up with the place I have to keep up with. Its needed far less often the last couple years but still indispensable.
circus
PostPosted: Thu May 17, 2018 10:27 am    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
Don't want to anthropomorphize the emerald ash borer but, after they kill all the ash, they'll also die. Wonder if a sucker from the root, left to grow into a tree, be safe?
parisspringstom
PostPosted: Thu May 17, 2018 12:59 pm    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
I dug under a stump and used a 20 ton jack to pop it loose and then drug it with the tractor. It was a lot of work if you have acess to larger equipment.
showcrop
PostPosted: Thu May 17, 2018 2:54 pm    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
PC 600
Caryc
PostPosted: Sat May 19, 2018 5:23 pm    Post subject: Re: Pulling out dead trees Reply to specific post Reply with quote
Here's a good way to get extra leverage when pulling anything. Something like a railroad tie works well in position B.
Page 2 of 3
