F-2 transmission
Larry Hyde
PostPosted: Mon Jun 11, 2018 8:43 am    Post subject: F-2 transmission Reply to specific post Reply with quote
I have 2 f-2's one is a hydro the other direct drive. The trans on the hydro either needs a rebuild or is toast,as it makes a lot of crunchy noises on the high side. I assume there is no way I can swap trannys as the hydro has no reverse. How hard is it to repair/replace the transmission ? Are they hard to find and do they cost less than a scrapper combine that's been messed up ? Any thoughts would be appreciated. Got a feeling crawling under one of these beasts is not a pleasant experience.
JimIA
PostPosted: Mon Jun 11, 2018 8:49 am    Post subject: Re: F-2 transmission Reply to specific post Reply with quote
Where do you live? I might be able to point you to a dealer that can help you.
Jim
Larry Hyde
PostPosted: Mon Jun 11, 2018 9:38 am    Post subject: Re: F-2 transmission Reply to specific post Reply with quote
I haven't talked to the local dealers yet. I'm only 1 1/2 hrs. South of Worthingtons in St. Johns MI. I do most if not all the work on these beasts, don't know if I can afford the labor rates, and hauling it would add to the costs.
Bob Bancroft
PostPosted: Mon Jun 11, 2018 12:31 pm    Post subject: Re: F-2 transmission Reply to specific post Reply with quote
There's lots of those combines around, so finding what you need shouldn't be a problem.
As far as crawling around under the machine- you're right. It's not fun, but not terrible. It depends on how old you are! I was a lot younger the last time I did it.
We had a floor jack under the tranny, and a come along on the input pulley to balance it.
JimIA
PostPosted: Tue Jun 12, 2018 5:50 am    Post subject: Re: F-2 transmission Reply to specific post Reply with quote
Call B&G Equipment in Paris TN. Talk to Tim. He can give you some pointers and may have a spare transmission for you.
JMS/.MN
PostPosted: Tue Jun 12, 2018 10:51 am    Post subject: Re: F-2 transmission Reply to specific post Reply with quote
Might be a good idea to remove one drive wheel...makes crawling around under there easier. I use large blocks I made by bolting together 4 pieces of 5x6 square post material, 16 inches long. Gives me heights of 10, 12, 16 inches, depending how they are turned. Very sturdy blocking.
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
