Oliver plow
Goto page 1, 2  Next
sowhatofit
PostPosted: Wed Jun 13, 2018 5:53 am    Post subject: Oliver plow Reply to specific post Reply with quote
Hello everyone, looking for some help getting this plow I picked up last night functional. First of all it appears to lean to the right -what might cause this (besides the tires of course)? And what size tires should be on this? Right now they appear to be whatever was lying around.
Also with the plows crank turned all the way in, the plows still are pretty far down and drag when pulling. Is there an Adjustment for this?
Identification of model would help too- I'm thinking it's a plowmaster 100?
I appreciate any feedback/advice. Thanks!
Olliejunkie
PostPosted: Wed Jun 13, 2018 7:24 am    Post subject: Re: Oliver plow Reply to specific post Reply with quote
I'm no expert but I think after you make your first pass the left tire would run in the furrow leveling it out.
farmerwithmutt
PostPosted: Wed Jun 13, 2018 7:40 am    Post subject: Re: Oliver plow Reply to specific post Reply with quote
I think its tripped . In other words trip
again pull forward and it will come up on
that side
Lee E. Smith
PostPosted: Wed Jun 13, 2018 8:06 am    Post subject: Re: Oliver plow Reply to specific post Reply with quote
This Oliver plow model was identified as a "Heavy Duty" plow. The lighter weight plow series were known as the "plowmaster"series.
As a 2-bottom plow, it would be identified as a 2-14 ; 2-16 plow.
sowhatofit
PostPosted: Wed Jun 13, 2018 8:14 am    Post subject: Re: Oliver plow Reply to specific post Reply with quote
CVPost-Farmerwithmutt wrote:
(quoted from post at 08:40:32 06/13/1Cool I think its tripped . In other words trip
that side
The trip lever is the lever in the right if you were to look back from the tractor?
OliverNate
PostPosted: Wed Jun 13, 2018 12:59 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
Yes, chances are if its been sitting for some time that drive hub will need to be taken apart and cleaned and make sure every thing spins and probly need new
springs. Its been a while since I did mine so I don't remember how it looks in there. But I was able to find off the shelf springs at local farm store that
worked.
sowhatofit
PostPosted: Wed Jun 13, 2018 1:17 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
CVPost-OliverNate wrote:
(quoted from post at 13:59:57 06/13/1Cool Yes, chances are if its been sitting for some time that drive hub will need to be taken apart and cleaned and make sure every thing spins and probly need new
worked.
Springs seem to be working, although they are pretty rusty. Never tore apart a hub like that. Any reference materials availabale online?
Plowman
PostPosted: Thu Jun 14, 2018 2:21 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
Hi I have manuals and parts for those plows. Thanks Steve 419-618-0017
J.Wondergem
PostPosted: Sat Jun 16, 2018 2:29 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
It's tripped. One of mine looks just like it except for the tail wheel, which is rubber.
sowhatofit
PostPosted: Sat Jun 16, 2018 2:49 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
J.Wondergem wrote:
(quoted from post at 15:29:38 06/16/1Cool
I'm guessing this one used to have rubber on it too. Any problems running it without the rubber? Other solutions?
J.Wondergem
PostPosted: Sun Jun 17, 2018 4:20 am    Post subject: Re: Oliver plow Reply to specific post Reply with quote
When I first got it, I had to lube up the lift with oil an free it up. Use the lever on the right to level the plow, an the crank for the depth, when it's in the ground. They plow nice.
OliverNate
PostPosted: Sun Jun 17, 2018 7:12 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
That's how some came, I think I have two with front wheels rubber and rear is that steel disc wheel and another two that are spose to be full steel but the front
two where cut off and a rim welded on.
sowhatofit
PostPosted: Tue Jun 19, 2018 1:57 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
Any idea what size tires should go on it?
OliverNate
PostPosted: Tue Jun 19, 2018 2:17 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
I think I took 6.00-16s off on mine but put 6.50-16s on because thats what I had.
sowhatofit
PostPosted: Tue Jun 19, 2018 3:29 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
(quoted from post at 15:17:16 06/19/1Cool I think I took 6.00-16s off on mine but put 6.50-16s on because thats what I had.
Any idea what radial tire would fit in it? Have a few lying around
Goto page 1, 2  Next
Page 1 of 2
