super M
gburt
PostPosted: Thu Jun 14, 2018 8:44 am    Post subject: super M Reply to specific post Reply with quote
Having problems with the throttle on our super M it does not rev up like it used to.I have adjusted the linkage but that did not seem to help I was just wondering if their was some else I was missing.
used red MN
PostPosted: Thu Jun 14, 2018 9:25 am    Post subject: Re: super M Reply to specific post Reply with quote
If no extreme wear or bending in the throttle linkage then the governor spring number 49 on the
attached parts page may be your problem. Otherwise wear in parts 39-46 contribute to this issue.
SM IH governor parts page
old
Have you had the carb off?? If yes you may not have the gov to carb hooked up correctly.
gburt
PostPosted: Thu Jun 14, 2018 11:26 am    Post subject: Re: super M Reply to specific post Reply with quote
CVPost-old wrote:
(quoted from post at 10:25:26 06/14/1Cool Have you had the carb off?? If yes you may not have the gov to carb hooked up correctly.
whats a good way to see if its hooked up correctly ?
old
PostPosted: Thu Jun 14, 2018 12:11 pm    Post subject: Re: super M Reply to specific post Reply with quote
That can be hard to explain. The carb linkage has a small slot that hooks to the governor and if not in that slot it is hooked up wrong.
used red MN
PostPosted: Thu Jun 14, 2018 7:57 pm    Post subject: Re: super M Reply to specific post Reply with quote
You basically have to pull the carb down or take the two bolts out that hold no. 19 to the governor
housing. Number 23 in the diagram is the shaft that moves the motion from the governor to the
carb. It is in side the horizontal tube that connects to the carb. The tang sticking out the right end
in the diagram goes in a notch on the end of the throttle plate shaft. If you had the carb off it could
likely not be in the right place. It is real tricky to get back in correctly. Just takes some time and
patience. If you had the carb off check this first. Otherwise let us know and we?ll give more details
on other adjustments.
gburt
PostPosted: Sun Jun 17, 2018 8:26 pm    Post subject: Re: super M Reply to specific post Reply with quote
every thing looks like it is hooked up right
