Oliver plow
Goto page Previous  1, 2
OliverNate
PostPosted: Wed Jun 20, 2018 5:27 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
Whatever you got thats skinny and tall. If they are 16in rims on there I'd look for like a 225/75R16 those are probly a bit too wide but that's probly the
closest you'll get in a radial. Unless you change rims but then you'll need fine thread bolts and lug nuts from a car to fit bolts because those rims have a
square hole for the lug holes and are held on by carriage bolts.
sowhatofit
PostPosted: Wed Jun 20, 2018 6:03 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
Ok,thanks. Looks like some of the carriage bolts are semi new, so shouldn't be too hard to get them off.
Also wondering if this implement will hill beyond the tire. I suppose that depends on speed? I'm row planting and may need to hill up on the plants. Never had a plow before. Just a disc and a cultivator/tine tiller.
OliverNate
PostPosted: Thu Jun 21, 2018 8:25 pm    Post subject: Re: Oliver plow Reply to specific post Reply with quote
The front bottom will take the soil and flip it upside down directly behind the tire. You could do some experimenting but I doubt its going to do what you want
it to. If you have light and loose soil it might work but you going to need the furrow tire as close as possible to the plant. Also they tend to not turn ground
the best when the furrow wheel is not in a furrow. Typically when you plow the first pass you gotta set it deep so the front board gets in the ground. This is
also when they are the worst for plugging because those old plows have no trash clearance. For what you want to do I'd be on the look out for a row cultivator
with disc hillers on it.
Page 2 of 2
