1981 JOHN DEERE 450C CRAWLER HYDRAULIC HOSE REPLACEMENT
SOLAUGHING
PostPosted: Tue Jul 17, 2018 10:11 am    Post subject: 1981 JOHN DEERE 450C CRAWLER HYDRAULIC HOSE REPLACEMENT Reply to specific post Reply with quote
Good day ..just wondering if anyone has a solution to remove the bucket tilt hyd hoses with out taking all pivot points apart..I was advised to cut a hole in the casting / housing and build a special wrench...any better plan out there ?
shinnery
PostPosted: Tue Jul 17, 2018 9:00 pm    Post subject: Re: 1981 JOHN DEERE 450C CRAWLER HYDRAULIC HOSE REPLACEMENT Reply to specific post Reply with quote
This on a loader bucket or backhoe? If a hoe what model?
DrLoch
PostPosted: Thu Jul 19, 2018 4:30 am    Post subject: Re: 1981 JOHN DEERE 450C CRAWLER HYDRAULIC HOSE REPLACEMENT Reply to specific post Reply with quote
On mine the tilt cylinder hoses come out the top and were easy to get at. The lift cylinders aren't. I removed the rear pin and retracted the cylinder to get the barrel to come out of the pocket. Ans yes I had to a number of different wrench combinations to replace. Crows feet, offset, regular and a lot of choice words that really didn't seem to help
SOLAUGHING
PostPosted: Fri Jul 27, 2018 11:36 am    Post subject: Re: 1981 JOHN DEERE 450C CRAWLER HYDRAULIC HOSE REPLACEMENT Reply to specific post Reply with quote
shinnery wrote:
(quoted from post at 22:00:01 07/17/1Cool This on a loader bucket or backhoe? If a hoe what model?
GOOD DAY..AS STATED IN THE HEADER THIS IS A 1981 450C CRAWLER {TRACKS}..THE HOSES ARE BURIED IN THE CYLINDER MOUNT POCKET...WE WERE TOLD TO TORCH A HOLE IN THE SIDE TO GAIN ACCESS..SEEMS PRETTY EXTREME TO ME ???!!!
SOLAUGHING
PostPosted: Fri Jul 27, 2018 11:51 am    Post subject: Re: 1981 JOHN DEERE 450C CRAWLER HYDRAULIC HOSE REPLACEMENT Reply to specific post Reply with quote
CRAWLER WITH TRACKS...BUCKET ON THE FRONT ONLY..ALL ENDS OF HOSES ARE BURIED IN THE TOP OF THE CYLINDER POCKET....CUTTING THE HOUSING OR REMOVING EVERY PIVOT PIN LOOKS
LIKE THE ONLY WAY...SAD
SOLAUGHING
PostPosted: Wed Sep 12, 2018 10:27 am    Post subject: Re: 1981 JOHN DEERE 450C CRAWLER HYDRAULIC HOSE REPLACEMENT Reply to specific post Reply with quote
NO LUCK ON AN ANSWER EH ???....SNOWS A COMING ..REAL FAST ...HELP
DrLoch
PostPosted: Thu Sep 13, 2018 4:44 am    Post subject: Re: 1981 JOHN DEERE 450C CRAWLER HYDRAULIC HOSE REPLACEMENT Reply to specific post Reply with quote
CVPost-SOLAUGHING wrote:
(quoted from post at 14:27:28 09/12/1Cool NO LUCK ON AN ANSWER EH ???....SNOWS A COMING ..REAL FAST ...HELP
Don't understand the question, it can and has been done without cutting holes in the machine. But if you are determined to cut holes to access the the fittings go right ahead. Is it easy, no.
Ozlander
PostPosted: Thu Sep 13, 2018 3:55 pm    Post subject: Re: 1981 JOHN DEERE 450C CRAWLER HYDRAULIC HOSE REPLACEMENT Reply to specific post Reply with quote
Could have been done by now.
