Front end wobble
Goto page Previous  1, 2
Ellis Kinney
PostPosted: Wed Oct 03, 2018 7:46 pm    Post subject: Re: Front end wobble Reply to specific post Reply with quote
Something else to try, Thanks, Ellis
Ellis Kinney
PostPosted: Wed Oct 03, 2018 7:48 pm    Post subject: Re: Front end wobble Reply to specific post Reply with quote
I have one of those on another tractor. I can't tell any difference. Ellis
Bill in IL
PostPosted: Fri Oct 05, 2018 5:33 am    Post subject: Re: Front end wobble Reply to specific post Reply with quote
I had and H that had death wobble. I spun the steering so the wheels spun 180 degrees and the wobble went away. Not sure if it really matters or if i just changed the wear to a less worn spot.
rustyfarmall
PostPosted: Fri Oct 05, 2018 5:58 am    Post subject: Re: Front end wobble Reply to specific post Reply with quote
CVPost-Bill in IL wrote:
(quoted from post at 06:33:14 10/05/1Cool I had and H that had death wobble. I spun the steering so the wheels spun 180 degrees and the wobble went away. Not sure if it really matters or if i just changed the wear to a less worn spot.
One of the 4 bolts that hold the lower bolster to the upper is supposed to be a stop bolt that prevents turning 180 degrees. If that bolt is missing, maybe the wheels had already been turned 180 degrees?
Whatever the case may be, you've got me thinking.
Loren in WI
PostPosted: Wed Oct 10, 2018 4:08 pm    Post subject: Re: Front end wobble Reply to specific post Reply with quote
You need to replace the upper and lower bushing in the bolster.
Page 2 of 2
