58 Fergie TO-35 Diesel Rims
graham_in_NJ
PostPosted: Tue Oct 09, 2018 5:42 am    Post subject: 58 Fergie TO-35 Diesel Rims Reply to specific post Reply with quote
I am restoring my 58 Ferguson with the Standard diesel.
So....after sandblasting, priming, sanding, and painting my front rims, I went to get tires and tubes. After researching, I had determined that I needed 6.00X16 3 rib. I get to the tire store and the owner tells me that the rims looked like 15 inch rims. I never thought to measure them! He tells me that those rims require a 7.5L 15 tire.
The rims do look like Fergie rims. Based on the condition of the tractor, it appeared that it was never messed with. I thought everything was original.
My question is: since this is a diesel, are these rims possibly correct?
My TO 30 does have 6.00 x 16 tires on it, so I have the wonderful opportunity to sandblast and paint them if I need to. Not really looking forward to that.
Tom H.
PostPosted: Tue Oct 09, 2018 2:28 pm    Post subject: Re: 58 Fergie TO-35 Diesel Rims Reply to specific post Reply with quote
Measure the TO30 rims and see if they are the same. The early tires had bigger/longer sidewalls because they require tubes. Modern wheels
are different as the tire seals on the bead of the rim and are tubeless.
Tom H.
Ps. Nice job on the rims
scott mcintosh
PostPosted: Tue Oct 09, 2018 6:19 pm    Post subject: Re: 58 Fergie TO-35 Diesel Rims Reply to specific post Reply with quote
Your rim has the proper offset so I would put the 7.5L-15 tires on it and not worry.The wider wheel gives more flotation also previous owner could have had a loader on it at one time.Scott
DrLoch
PostPosted: Wed Oct 10, 2018 4:17 am    Post subject: Re: 58 Fergie TO-35 Diesel Rims Reply to specific post Reply with quote
That's the same rim I have on my 1960 TO35 Diesel.
graham_in_NJ
PostPosted: Fri Oct 12, 2018 4:24 am    Post subject: Re: 58 Fergie TO-35 Diesel Rims Reply to specific post Reply with quote
Thanks for the answers! 7.5's it is then.
Ron(Ont)
PostPosted: Fri Oct 12, 2018 8:51 am    Post subject: Re: 58 Fergie TO-35 Diesel Rims Reply to specific post Reply with quote
A couple of thoughts. I have similar rims on 2 TEA's. The 1st has 6" rubber and steers fairly well. The 2nd has 7.5" rubber and steers like a tank. The rims had to be flipped inside out so that the rubber did not rub on the spindles.
