telescoping gooseneck hitch
bjsons
PostPosted: Sat Mar 09, 2013 10:18 am    Post subject: telescoping gooseneck hitch Reply to specific post Reply with quote
thinking of trying to make a lite weight lo profile car hauler with a gooseneck hitch to be tilting...
Seems to me one should be able to use a cylinder in the neck to raise the whole trailer
anyone ever seen this or tried it?
thanks
caterpillar guy
PostPosted: Sat Mar 09, 2013 4:21 pm    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
Yup saw one at the sale in Archbold Oh one time. The neck just tilted forward as the deck came up. That let the tail hit the ground. You can probably buy one if you look around. To make one would be a lot of work and cost.
Welding man
PostPosted: Sun Mar 10, 2013 5:36 am    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
Why not just built a tilt bed gooseneck. Very simple, subframe it back to near the front spring hanger and add a hyd cylinder and a 12v. powerpack to do the tilting?
bjsons
PostPosted: Sun Mar 10, 2013 9:18 am    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
Yes, I could probably buy one but have the goosseneck trailer already, and just want to eliminate ramps...felt it should be easy to raise to design something but am kind at a loss on exactly what ....
In otherwords..looking for a cheap-(isn't everyone?) easy fix...
I know years ago there were some machinery trailers that raised the hitch to tilt..but can't seem to find any info now.
Thanks for the response and your advice..I do not often actually post on this forumn but do read a lot ...good site
thanks
Mike
Welding man
PostPosted: Sun Mar 10, 2013 1:11 pm    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
Our tractor clubs pulling sled has a tongue like I think you are talking about. It a has a hydraulic cylinder mounted to the side of the ball mount and a 12v Hyd power pack. I will take some pictures. I have also seen a gooseneck ball mount mounted on a square trailer jack. Either of these set-ups will level the trailer but I don't think you can get enough travel to tilt the trailer for loading. I personally like the idea of a hydraulic dovetail.
ericlb
PostPosted: Sun Mar 10, 2013 5:19 pm    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
you might also take a look at one of those equipment trailers that semis have where the axles slide forward hydraulically,that drops the rear of the trailer on the ground,its loaded,then the axles are slid back into position for travel,you might be able to duplicate that setup on your trailer ,im not sure if you can get the gooseneck to raise enough to get the back end to the ground, unless you use a long cylinder like for a dump truck which is very heavy ,and pivoting with the axles being the hinge, it would have to go quite a way up to get the backend on the ground it might be too steep to load then
farmeracb
PostPosted: Sun Mar 10, 2013 6:21 pm    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
Look at Landoll 300 series on their website, you might get some ideas for yours, or watch for a used one like that as they aren"t real expensive. I have one that I haul tractors in with. Upside, haul anything. downside, heavy, max load is about 20000, and too much for a dually pickup, too little for a road tractor. Hope it helps. Adam
Meangreen
PostPosted: Mon Mar 11, 2013 11:04 am    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
Look at this...
Check this out
bjsons
PostPosted: Tue Mar 12, 2013 1:44 pm    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
thanks for all comments....I already have the trailer built that I want to tilt..
Welding man...could you e-mail me a pic sometime of the one your club has?
Just looking for the easiest way to tilt an existing trailer...
I have seen the ones where the whole gooseneck hitch tilts--that would be my next option but would take quite a bit more effort....
thanks again
Mike
bjsons@pinenet.com
Welding man
PostPosted: Tue Mar 12, 2013 4:49 pm    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
Mike, The sled is about 5 miles away ,I will try to get you some pictures in a couple of days.
ericlb
PostPosted: Wed Mar 13, 2013 3:21 am    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
dang! i wish id seen this before i bought my new trailer,guess im old fashioned now with using ramps, a consignment lot up in the next town went me another one better, a 80's or 90's freightliner day cab cabover tractor with a roll back bed on it and a nice 20 ton winch but man i dont need another 4 mpg truck!
504-1
PostPosted: Fri Apr 05, 2013 5:59 pm    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
There is one down the road that has a telescopic post for a hitch, heavy square tubing sliding in a square tube with a hyd cyl on the out side to lift it(telescope) It could be built in to almost any trailer.
charles todd
PostPosted: Mon May 20, 2013 9:31 pm    Post subject: Re: telescoping gooseneck hitch Reply to specific post Reply with quote
My next trailer will be a State Line GTH (goose tilt high deck). Little more cost, but, WHOA! Easy to load.
http://sltrailers.com/GH_Tilt_Bed_Hi_DeckS.html
CT
Post new topic    Yesterday's Tractors Forum Index -> Tractor Transporting All times are GMT - 8 Hours
