Gleaner L M questions
R Wyler
PostPosted: Sat Mar 09, 2013 7:22 pm    Post subject: Gleaner L M questions Reply to specific post Reply with quote
What all relies on electric controls on these? I understand they use solenoids use a toggle switch for the header lift ect. What about the seperator clutch and unloader auger? Also if I understand they come with hyrdo and gear drive. So the hydro traction drive is the same as my old A with variable speed?
JMS/.MN
PostPosted: Sat Mar 09, 2013 9:13 pm    Post subject: Re: Gleaner L M questions Reply to specific post Reply with quote
All hyd controls are electric over hyd. Rocker switches send current to the solenoids on each hyd valve, rather than a mechanical linkage. Seperator clutch is electric. Unloading auger belt is tightened by hyd cyl. Hydro drive is not a gear drive......hydro has multiple gear ranges with infinite fwd/reverse speeds and instant change of direction in each range.
agonair
PostPosted: Sun Mar 10, 2013 4:24 am    Post subject: Re: Gleaner L M questions Reply to specific post Reply with quote
Th only things controlled with mechanical linkage are throttle and hydro-traction drive (if equipped).
everything else is electric over hydraulic. If has a variable speed, then it is electric over hydraulic. We had an M, M2, and M3 and never experienced troubles with the electrical. They work well.
Mark (EC,IN)
PostPosted: Sun Mar 10, 2013 6:05 am    Post subject: Re: Gleaner L M questions Reply to specific post Reply with quote
Weren't these the first combine to use the electric over hyd controls, probably followed by IH?
All machines use them now.
R Wyler
PostPosted: Sun Mar 10, 2013 8:18 am    Post subject: Re: Gleaner L M questions Reply to specific post Reply with quote
Thanks for the responses. That is what I was thinking on the controls. Parts are readily available fast also in my area. From what I understand most want the hydro. I can see how they are nice because you can go as slow as you need to.
big orange
PostPosted: Mon Mar 11, 2013 2:51 pm    Post subject: Re: Gleaner L M questions Reply to specific post Reply with quote
Straight M/L's and early 2 series had mechanical engage unloading auger, unfolding swing out was electric over hydraulic.
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
