another 3020 question
johnwayne360
PostPosted: Fri Mar 15, 2013 5:01 am    Post subject: another 3020 question Reply to specific post Reply with quote
Got the 3020 started today. Forgot that it needed a quart of oil, so I dumped one in while it was running, didnt want to shut it off right away. Saw bubbles coming back up the oil tube as i dumped oil in. If im losing coolant, its not much, but the head gasket does weep some oil, planning on fixing that this summer. Question..is that a symptom of a head gasket, or is something more wrong?
Bob
PostPosted: Fri Mar 15, 2013 5:09 am    Post subject: Re: another 3020 question Reply to specific post Reply with quote
Does it weep oil on the RH (pushrod) side of the head gasket? If so, that is quite common and does NOT necessarily explain coolant loss.
johnwayne360
PostPosted: Fri Mar 15, 2013 8:43 am    Post subject: Re: another 3020 question Reply to specific post Reply with quote
its weeping on rh side head gasket. I dont think its losing coolant-if it is it is very little, not noticable over the last 50 hours of use anyway. I was just wondering if the compression leak through the oil would be indicating anything else other than a head gasket.
ET
PostPosted: Fri Mar 15, 2013 8:47 am    Post subject: Re: another 3020 question Reply to specific post Reply with quote
Piston blow-by. I have seen a dipstick bounce around on the volume of air trying to get out of the crankcase.
LITTLE RED
PostPosted: Fri Mar 15, 2013 8:51 am    Post subject: Re: another 3020 question Reply to specific post Reply with quote
Mine does the exact same thing but is also damp around # 2 cyl. and seeping a little collant out the weeap holes on the left side of motor.
tim s
PostPosted: Fri Mar 15, 2013 9:29 am    Post subject: Re: another 3020 question Reply to specific post Reply with quote
I"m surprised that you didn"t get an oil bath putting the oil in while running...
David G
PostPosted: Fri Mar 15, 2013 10:18 am    Post subject: Re: another 3020 question Reply to specific post Reply with quote
I would consider that normal, it is blowby escaping.
johnwayne360
PostPosted: Fri Mar 15, 2013 11:49 am    Post subject: Re: another 3020 question Reply to specific post Reply with quote
lol...mustnt be too much of a problem then..
4010 puller
PostPosted: Fri Mar 15, 2013 4:51 pm    Post subject: Re: another 3020 question Reply to specific post Reply with quote
yea..I learned this the hard way while working for a dairy farmer at about 16 years of age, adding oil to a 3020 or 4020. Only took once to learn.
NEIADan
PostPosted: Fri Mar 15, 2013 5:26 pm    Post subject: Re: another 3020 question Reply to specific post Reply with quote
Is your oil seepage towards the rear right side of the engine in the distribuor area? We found it quite normal that the oil galley feeding oil to your rocker arms would eventually seep to the outside of the engine. There often is no combustion leekage or loss of coolant. Be sure and resurface the head and at least use a good sealant around that galley. Why Deere did not use a tube oil galley instead of relying on the gasket to seal this is a real question
