jd50 clutch noise
Fatman-littleboy62
PostPosted: Fri Mar 15, 2013 1:27 pm    Post subject: jd50 clutch noise Reply to specific post Reply with quote
I have a 1953 JD 50 that at idle makes a lot of noise but after engaging in any gear there is no noise at all. I thought a wore out throw out bearing was just the opposite, noisy while engaged , quiet at idle. Any ideas?
Bob Harvey
PostPosted: Fri Mar 15, 2013 1:31 pm    Post subject: Re: jd50 clutch noise Reply to specific post Reply with quote
Could be first reduction gear(s)and /or bearing(s). Check the oil in there. HTH
buck eye al
PostPosted: Fri Mar 15, 2013 1:44 pm    Post subject: Re: jd50 clutch noise Reply to specific post Reply with quote
If it is a "metallic rattling" sound it is possibly the sliding drive disk loosely rattling on the splines of the clutch driver. When the clutch is engaged the sliding drive disk is tightly squeezed in the pack & so it doees not rattle but he flywheels ahead and back on the driver when the clutch is NOT engaged. Often the noise is greater at slow engine speeds than high.
M w J
PostPosted: Fri Mar 15, 2013 2:43 pm    Post subject: Re: jd50 clutch noise Reply to specific post Reply with quote
The bearing in the clutch on a 50 turns with the clutch disengaged and does not turn when the clutch is engaged. The bearing could be dry or shot but do not run it if it is bad. A bearing on a 50 that is bad will wreck the crankshaft real fast.
