12 Volt Conversion - Fried two Alternators
Goto page 1, 2  Next
HeyObie
PostPosted: Sat Mar 16, 2013 6:36 am    Post subject: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
I converted my side mount 8N from 6V to 12V with a kit I bought. The kit came with mounting brackets, alt, and new 12V coil. I hooked it up and started right up and was charging around 14V. Everything looked fine.
I started it another day, and I noticed the ammeter was all the way to the right over charging. I noticed my battery was bubbling out the top. I put a meter on the battery and it was reading around 20V.
The company I bought it from sent me a relalcement alt. I put it on and the same result. Worked perfect for a short while. Then the battery started bubbling again and the ammeter over to the right charging 20V.
It is a single wire alternator. The wire that is connected to the alt is hot even with the key off. Negative ground.
I called the company and they will refund, but I need to send it all back. They don't love me anymore.
The tractor runs fine. Obviously, I have something wrong.
old
PostPosted: Sat Mar 16, 2013 7:43 am    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
Some 1 wire alternators are bastardized 3 wire ones that do not work as they should. Me I do my own wiring and use the common Delco 10si like what would come on a 1980 Chev pick up no power any thing no AC. Easy to wire up and if you have an O'Reilly's close by you can buy them for around $45 plus a core of $10.
HeyObie
PostPosted: Sat Mar 16, 2013 7:51 am    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
We have Napa around here and can get one for $49. It is a three wire. Can you share how to wire it up? Or is it too hard to explain.
old
PostPosted: Sat Mar 16, 2013 7:59 am    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
I never do the 1 wires any more due to odd problem caused by them. Like battery drain and high RPMs needed to exciter them etc. The 3 wire ones are simple to hook up and if as I said you have an O'Reilly's close to you they come with a lift time warranty so if it does go bad you can take it back and get a new one for free. The 3 wire has as it says 3 wires. The big charge wire which you hook like the 1 wire and then a plug with a #1 and #2 wire. The #2 goes to the charge stud on the alternator and the #1 with a diode in line radio shack #276-1661 goes to the ignition side of the coil or the ignition switch the coil side and your done
notjustair
PostPosted: Sat Mar 16, 2013 8:20 am    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
When replacing an alternator on a car one time I went through 4 of them before one finally worked. I had been getting the from the auto place. I finally got smart and got a Bosh like it came with. Problem solved.
Take that alternator and have it tested. If it is bad get a new one and have them test it before you leave the store. That takes that out of the equation.
HeyObie
PostPosted: Sat Mar 16, 2013 8:25 am    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
I had a similar problem with my daughter's eclipse. I went through 2 after market alternators. A mechanic told me that the company that rebuilt them had bad parts until it was caught. Had to buy an oem and everything was fine
I am going to Radio shack and then Napa for the alternator.
HeyObie
PostPosted: Sat Mar 16, 2013 11:25 am    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
Old,
Let me see if I have this right in my own words:
1 - the large wire connected at the starter/battery connection, connects to the alternator at the charging stud.
2 - Connect a wire from the #2 connection on the alternator and attach it to the charging stud
3 - Connect a wire from the #1 connection on the alternator and attach it to the coil side of the ignition switch.
Which way does the diode face? Does the ring on the diode face away from the alternator or toward it?
Thanks,
Obie
notjustair
PostPosted: Sat Mar 16, 2013 11:28 am    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
Google it - there are good diagrams out there. I only use the three wire jobs. They are simple to do.
souNdguy
PostPosted: Sat Mar 16, 2013 12:45 pm    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
ring on diode ( cathode ) toward alternator....
any 1+a / 50 PIV+ diode will work.
a 3a/200piv is much prefered..
xring 223
PostPosted: Sat Mar 16, 2013 12:46 pm    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
I just put a 12 volt conversion on my 2N It stays on 0 while running high rpm"s don"t help I got it on e-bay for a $100 free shipping. When the lights are on it discharges it is also a one wire unit I put on new wire that came with it and followed instructions, checked twice,other than going to a three wire any help?
HeyObie
PostPosted: Sat Mar 16, 2013 1:03 pm    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
[/img]
Royse
PostPosted: Sat Mar 16, 2013 3:00 pm    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
Xring, you might check to make sure you have the right pulley and that it and the belt are tight.
A parts store will test the alternator for free if you want to rule that out as a cause.
You might also check and see if your one wire alternator has all three terminals.
If it does I've read on here (Old maybe?) that you can sometimes wire them as a three wire.
Hobo,NC
PostPosted: Sat Mar 16, 2013 3:15 pm    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
A voltmeter would have tipped you off before the amp meter would...
Add are replace the amp meter with a voltmeter...
Nutter reason to ditch the amp meter... Mad
old
PostPosted: Sat Mar 16, 2013 6:15 pm    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
Many 1 wire set ups need 2000 plus RPM to excite and the N series engine has a problem doing that often so that is why i never say to use a 1 wire. BTDT and never again will I use the one wires
old
PostPosted: Sat Mar 16, 2013 6:37 pm    Post subject: Re: 12 Volt Conversion - Fried two Alternators Reply to specific post Reply with quote
Yes once in a while you can get lucky and wire a 1 wire like a 3 wire by adding the 2 wire plug but it does not work every time
Goto page 1, 2  Next
Page 1 of 2
