wd trans fluid
Travis Jenkins
PostPosted: Sat Mar 16, 2013 7:02 am    Post subject: wd trans fluid Reply to specific post Reply with quote
anyone know how much 90w the trans in a wd holds
old
PostPosted: Sat Mar 16, 2013 7:30 am    Post subject: Re: wd trans fluid Reply to specific post Reply with quote
I-T manual page 5 says it holds 6qts.
john prince
PostPosted: Sat Mar 16, 2013 9:01 am    Post subject: Re: wd trans fluid Reply to specific post Reply with quote
no on the wd the trans and diff. are one unit and hold 17 quarts i have a wd and the manual you didn"t go over far enough
Travis Jenkins
PostPosted: Sat Mar 16, 2013 10:24 am    Post subject: Re: wd trans fluid Reply to specific post Reply with quote
ok so 17qts in the trans/diff what about the front trans?
Aaron SEIA
PostPosted: Sat Mar 16, 2013 10:37 am    Post subject: Re: wd trans fluid Reply to specific post Reply with quote
There is only one tranny. 6 qts of oil in the hydraulic system, 17 qts in the tranny. I use 10-30 in the hyd, others use hyd-tran type oil. Book says 80EP for tranny. Dad runs hy-trans oil in his and does just fine.
AaronSEIA
Travis Jenkins
PostPosted: Sat Mar 16, 2013 10:41 am    Post subject: Re: wd trans fluid Reply to specific post Reply with quote
ok thank you for the help
Travis Jenkins
PostPosted: Sat Mar 16, 2013 10:47 am    Post subject: Re: wd trans fluid Reply to specific post Reply with quote
I just pulled the fill cap off next to my hand clutch an mines filled with 90W
Aaron SEIA
PostPosted: Sat Mar 16, 2013 10:49 am    Post subject: Re: wd trans fluid Reply to specific post Reply with quote
The hyd fill and dipstick is on the left side just ahead of the clutch pedal just inside the frame. Tranny, diff, and hand clutch all have drains at the bottom of each. Hand clutch and tranny/diff have separate fill holes on left side of tranny. Fill to level with hole.
AaronSEIA
old
PostPosted: Sat Mar 16, 2013 6:28 pm    Post subject: Re: wd trans fluid Reply to specific post Reply with quote
Crossed lines and got engine oil instead of trans/rear end.
