Author |
Message |
TheOldHokie Tractor Guru
Joined: 08 Apr 2005 Posts: 9355 Location: Myersville, MD
Posted: Sat Mar 16, 2013 11:58 am Post subject: Itty bitty remotes |
Just finished this live hydraulics conversion for a customer who also wanted a small single spool Prince valve and two quarter inch remotes for "little" jobs. At 2.5 GPM it ain't going to run a loader but it should handle the customer's top link just fine. As I was looking at it I'm thinking it would easily handle a snow plow. Or a two spool valve and a couple small cylinders on the lift arms could turn a back blade into a very nice terracing/ditching setup.
TOH
Last edited by TheOldHokie on Sat Mar 16, 2013 12:01 pm; edited 2 times in total |
Back to top |
Roger in Iowa Tractor Expert
Joined: 12 Oct 2007 Posts: 2615 Location: Ottumwa, Iowa
Posted: Sat Mar 16, 2013 12:05 pm Post subject: Re: Itty bitty remotes |
Looks nice. Where/what is the pump and reservoir? |
Back to top |
souNdguy Tractor Guru
Posted: Sat Mar 16, 2013 12:35 pm Post subject: Re: Itty bitty remotes |
a t2.5gpm.. it's almost like the N internal pump.. which many ran loaders off of. :)
no speed demon.. but better than a wheel barrow!
looks nice. as usual for your creations... |
Back to top |
Posted: Sat Mar 16, 2013 12:49 pm Post subject: Re: Itty bitty remotes |
Roger in Iowa wrote: | (quoted from post at 16:05:19 03/16/13) Looks nice. Where/what is the pump and reservoir? |
The remotes are just an add-on to my standard belt drive live hydraulics conversion that uses the tractor sump. I didn't have the suction line hooked up when I took these pictures but it connects to the 2" drain in the OEM belly pump using a custom made adapter. The adapter is just a bushing that replaces the drain plug and turns the drain into a #12 SAE o-ring hydraulic port capable of accepting any standard SAE hydraulic fitting.
Back to top |
Posted: Sat Mar 16, 2013 12:54 pm Post subject: Re: Itty bitty remotes |
soundguy wrote: | (quoted from post at 16:35:01 03/16/13) a t2.5gpm.. it's almost like the N internal pump.. which many ran loaders off of.
Yeah but I can do a lot better than 2.5 GPM. The one on the assembly line right behind this one is 10+ GPM and has a two spool valve and 4 outlets. Will look almost identical - just bigger hoses and outlets and more of them.
TOH |
Back to top |
Posted: Sat Mar 16, 2013 1:13 pm Post subject: Re: Itty bitty remotes |
i figured that 2.5gpm one must be small like a sodacan or weedeater engine.  |
Back to top |
Jubilee85 (VA) Regular
Posted: Sat Mar 16, 2013 1:32 pm Post subject: Re: Itty bitty remotes |
WOW - from one hokie to another - dat dare is some fine engineering! I wish I had something that I could run with this nice pump.
OT - you ever keep up with the alt fuel car from VT? those guys won first place in the nation last year! the leader of the group was a former student of mine and a smart cookie, they brought the car by school, wow - talk about an engineering feat! |
Back to top |
Posted: Sat Mar 16, 2013 1:41 pm Post subject: Re: Itty bitty remotes |
Jubilee85 (VA) wrote: | (quoted from post at 17:32:17 03/16/13) WOW - from one hokie to another - dat dare is some fine engineering! I wish I had something that I could run with this nice pump.
The engineering departments have done some real nice stuff.
Maybe I could interest you in one of these to replace that Gawd Awful vane pump on your Jubilee
TOH
Back to top |
Colin King Tractor Guru
Posted: Sat Mar 16, 2013 2:33 pm Post subject: Re: Itty bitty remotes |
I really admire all of the ad-ons you come up with. Thanks for sharing!
Colin, MN |
Back to top |
Posted: Sat Mar 16, 2013 3:29 pm Post subject: Re: Itty bitty remotes |
Colin King wrote: | (quoted from post at 18:33:55 03/16/13) I really admire all of the ad-ons you come up with. Thanks for sharing!
Colin, MN |
I like to tinker. My mother started putting all of the clocks in our house up out of my reach about the time I started walking
TOH |
Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 21885 Location: Twin Cities
Posted: Sat Mar 16, 2013 5:11 pm Post subject: Re: Itty bitty remotes |
Very nice work TOH.
I assume this setup also gives the tractor live hydraulics? Live hyds is the biggest drawback on the N Series Fords and this would correct that.
One thought about your setup:
Maybe future installs could incorporate hard piping from the front to the rear?
Later Fords did a pretty good job with tucking the lines along the side of the chassis.
More work I know but the finished product would be much less Medusa-esque.
Back to top |
Posted: Sat Mar 16, 2013 6:52 pm Post subject: Re: Itty bitty remotes |
Wow! Looks nice... |
Back to top |
DollarBill Long Time User
Joined: 28 Jul 2008 Posts: 1376 Location: Keystone Heights, Florida
Posted: Sun Mar 17, 2013 3:31 am Post subject: Re: Itty bitty remotes |
Ultradog MN wrote: | One thought about your setup:
More work I know but the finished product would be much less Medusa-esque. |
What he said.
I'd like to convert my working girl to live hydraulics but the snake pit of loose rubber hoses has kept that project on hold until I could figure out a way to hard pipe it.
C'mon Dan, I know you can do it - How hard can it be for a pro like you!?  |
Back to top |
Posted: Sun Mar 17, 2013 8:02 am Post subject: Re: Itty bitty remotes |
haha! Nice :-)
Colin |
Back to top |
gwstang Tractor Expert
Posted: Sun Mar 17, 2013 8:41 am Post subject: Re: Itty bitty remotes |
Nice job, I too am envious of your work! You have what the kids now a days call "mad skilzs"...lol |
Back to top |
