Cooling fan motor for Miller Welder
SweetFeet
PostPosted: Sun Mar 17, 2013 5:55 am    Post subject: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
Were do you get a new cooling-fan motor for a Miller AC/DC welder?
I looked online at Airgas and Baker and all I find for parts are replacement lenses for helmets and stuff like that.
Mark-Ia
PostPosted: Sun Mar 17, 2013 6:29 am    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
Ebay, look for "Miller cooling Fan"
SweetFeet
PostPosted: Sun Mar 17, 2013 6:51 am    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
Mark IA,
Thanks. Did not even think of ebay.
kevinj54
PostPosted: Sun Mar 17, 2013 6:53 am    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
miller4less
Ultradog MN
PostPosted: Sun Mar 17, 2013 7:32 am    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
Don't forget about WW Grainger.
They can get you just about any kind of electric motor ever built.
JOB
PostPosted: Sun Mar 17, 2013 8:34 am    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
Would that be a dialarc 250. I have a miller that has a bad cooling fan right from the factory. If it is a bearing problem just replace the bearings.
Stick welding
PostPosted: Sun Mar 17, 2013 9:03 am    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
Airgas or any other welding supply doesn't stock cooling fans. The Miller warranty depot in your area may have the cooling fan or the welding supply can order it from Miller. A place that deals in electric motors may be able to match it up as well. If you go to the Miller website, you can look up the parts manual for the machine and get the part number. Have your serial number handy to get the right motor.
JMS/.MN
PostPosted: Sun Mar 17, 2013 10:26 am    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
Central McGowan in St. Cloud is a Miller dealer.
js305
PostPosted: Sun Mar 17, 2013 11:40 am    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
I replaced the fan motor on my Lincoln "crackerbox" after a few years of neglect (sitting outside). It didn't last long at all, the replacement looked like the fan out of a bathroom light. I got one of the sealed square fans, commonly called a muffin fan, that fit the hole nicely. That was twenty years ago. The machine still works really well for the quick job that doesn't require a lot of finesse.
JOB
PostPosted: Sun Mar 17, 2013 11:56 am    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
Another thought would be to have your old one repaired. There is an older man a little north of you in Inver Grove Heights that repairs AC motors. His partner repairs DC motors. Would most likely be better than getting ripped off on ebay or buying new from Miller. Just a suggestion
SweetFeet
PostPosted: Sun Mar 17, 2013 1:57 pm    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
Thanks for the replies everyone!
36 Coupe
PostPosted: Mon Mar 18, 2013 2:32 am    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
Oil the bushings before you replace the motor.My Lincoln 225 fan runs slower than normal when it needs oil.Bought the welder new in 1965 for 93.00.
mkirsch
PostPosted: Mon Mar 18, 2013 5:28 am    Post subject: Re: Cooling fan motor for Miller Welder Reply to specific post Reply with quote
Not for nothing but can't you get parts from a Miller dealer?
I thought the whole deal with buying the "good stuff" from a "reputable" brand like Miller was the friendly and helpful local dealer network.
