9N no spark
Trees132
PostPosted: Sun Mar 17, 2013 6:39 am    Post subject: 9N no spark Reply to specific post Reply with quote
Hi Guys!
I have been working on a 9N that was sitting outside for a long time. We replaced the main wiring harness, resistor, plug wires, cap, rotor, points, condenser and still do not have any spark. Just wondering if someone could but together a few diagnostic points to check. The starter is spinning well. It is currently set up as 6-v pos. ground and would like to keep it as such. Greatly appreciate the advice!
Josh
Bruce (VA)
PostPosted: Sun Mar 17, 2013 7:23 am    Post subject: Re: 9N no spark Reply to specific post Reply with quote
Before you check anything else, make sure you have the correct voltage at the top of the coil. It should be battery voltage w/ the points open & about half that w/ the points closed.
Assuming that the bushings & advance weights are ok, & that you have correct voltage to the coil, the most common electrical failure (no spark, weak spark) points on the frontmount are:
1. The insulator under the brass concave head screw & where the copper strip attaches. (it’s fiber & will wear out; poke & prod w/ your meter leads to make sure it still works)
2. The pigtail at the bottom of the coil not making contact w/ the concave head brass screw inside the distributor. (With the coil on, the pigtail must firmly contact the brass screw. No contact = no spark.).
3. The copper strip is broken or grounded to the plate. (look very carefully for cracks & breaks)
4. The condenser wire grounding to the plate or side of the distributor.
5. The tab on the bottom of the coil not making contact w/ the brass button on the cap. (With the cap on, the tab must firmly contact the brass button. No contact = no spark.)
6. Incorrect positioning of the spring clip on the plate causing the pigtail to ground. (the open part of the clip goes between 7 & 9 o’clock on the plate. That puts the straight part of the clip opposite of the timing screw at 3 o’clock)
7. Incorrect seating of the coil on the distributor due to a loose bail or no gasket.(the coil must not move at all; if it does, replace the gasket or bail. Or stick some cardboard under the bail).
8. Water/moisture inside the cap due to gasket failure or the absence of a gasket. (the cap AND coil have gaskets)
9. Dirty/corroded/burned/incorrectly gapped or misaligned points.
10. Burned rotor, cracked/carbon tracked cap.
Unless the coil is cracked or shows a dead short, chances are it's fine; square coils rarely fail cold. Pull the distributor & do a continuity check.
First, make sure your meter/light works (don't ask....)
You can change points everyday & it will not fix bad bushings. If you are having trouble w/ points failure, check the shaft. If you detect movement, chances are it needs new bushings.
Inspect the points; if they are pitted or burned, replace them. Next, dress the points by running a piece of card stock or brown paper bag through them. New points sometimes have an anti-corrosive dielectric coating on them & old points can corrode or pick up grease from a dirty feeler gauge or excessive cam lubricant. Make sure the points align correctly. Proper alignment is also critical to longevity. Look at the points when they are closed; both sides should mate evenly. Then, check the gap at .015 on the high point of all 4 cam lobes.
Now, follow these steps:
1. Coil off, cap off, points open. One probe on the brass screw & the other on both sides of the open points. On the side closest to the cam, you should have continuity. Not on the other side! If you do, you will also have continuity everywhere because the points are grounded.
2. Coil off, cap off, points open. One probe on the brass screw & the other anywhere on the body of the distributor. You should have no continuity! Now, rotate the tang on the distributor....as the points open & close, you have continuity (closed) and lose it when they open.
3. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other on the cam side of the open points. You should have continuity!
4. Coil on, cap off, points open. One probe on the lead on the top of the coil, the other anywhere on the body of the distributor. You should have no continuity!
At this point, I just put the distributor, coil & cap all back on the tractor as a unit. The reason I do this is because it is real easy to get the cap or coil mis-aligned trying to put it back together one piece at a time & the result is something gets broken or you get a ‘no spark’ problem.
It's possible to put it back on wrong & break it. Look at the slot on the end of the cam shaft. What ever angle it happens to be, turn the distributor tang to match it. Make sure you can tell the wide side from the narrow side on both the cam & distributor! (close counts) Then place the distributor on the front of the engine, gently push it in place & slowly turn the distributor body until you feel the tang slip into the slot. Rotate the distributor body until the bolt holes line up. Then, hand tighten the two bolts until the distributor body is flush w/ the timing gear cover.
Finally, double check your firing order & plug wires. It’s 1-2-4-3, counterclockwise. It’s very easy to cross 3 & 4.
Post back w/ results & any other questions.
75 Tips
tom bleeker
PostPosted: Sun Mar 17, 2013 8:00 am    Post subject: Re: 9N no spark Reply to specific post Reply with quote
i had the same problem as bruce said pig tail coil grounded.if the copper band is broke use copper srape from old points and punch holes.not my idea my brother inlaws he a milewright. i watched a guy on you tube install distributor with every thing coil and cap installed then put it on ( do not do it) install like bruce said make sure you fell it drop into slot or you will by a knew distributor . i told my self after i took old one apart i needed one any way . the inside was very loose main armiture where arms slide out . it was fait or my own screw up
souNdguy
PostPosted: Mon Mar 18, 2013 5:18 am    Post subject: Re: 9N no spark Reply to specific post Reply with quote
any joy yet?
what have you done on bruce's list so far?
Trees132
PostPosted: Tue Mar 19, 2013 10:59 am    Post subject: Re: 9N no spark Reply to specific post Reply with quote
Thanks for all the feedback. I havent had a chance to revisit the machine yet, but I will work on Bruce's list and will be in touch. I havent tried most of the suggestions.
souNdguy
PostPosted: Tue Mar 19, 2013 1:23 pm    Post subject: Re: 9N no spark Reply to specific post Reply with quote
let us know what ya find.
