730 camshaft
tim-m
PostPosted: Sun Mar 17, 2013 12:50 pm    Post subject: 730 camshaft Reply to specific post Reply with quote
Has anyone tryed to weld up a 730 Diesel camshaft injector lobe? or is a good replacement the only way to fix it? I have such a camshaft and found out from a tractor salvage yard it was a common problem along with the rollers that ride on these lobes that flake and pit. Any experience that you folks had with this would be appreciated, Thank You..
Hugh McKinney
PostPosted: Sun Mar 17, 2013 6:28 pm    Post subject: Re: 730 camshaft Reply to specific post Reply with quote
There is a machine shop in Houston that I have used on occasion; they can literally weld up and regrind your entire camshaft, and fairly economically. If you need the number I can get it for you. Hugh
Whichester1
PostPosted: Sun Mar 17, 2013 6:52 pm    Post subject: Re: 730 camshaft Reply to specific post Reply with quote
There are a couple of places that weld them up and advertise the regrind to produce 6-10% more power. I've only seen the ads in Green and Two Cylinder magazines and cannot personally conform. Should be able to Google to find the re-grinders if you don't take either of these magazines.
mkr100
PostPosted: Sun Mar 17, 2013 7:49 pm    Post subject: Re: 730 camshaft Reply to specific post Reply with quote
Hill Crest Cam shaft reworked mine. They did an excellant job.
Rich Duane
PostPosted: Mon Mar 18, 2013 4:40 am    Post subject: Re: 730 camshaft Reply to specific post Reply with quote
Tim,
I have the AR 20247 cam and AF 20168 R rollers new.You also want to check the key way on the drive end as they crack out. 410-643-2899
Geoff Mathews
PostPosted: Mon Mar 18, 2013 6:23 am    Post subject: Re: 730 camshaft Reply to specific post Reply with quote
I am planning to put 830 valves in my 730D - I would be grateful for thoughts on what to do with the camshaft - put a modified one in or leave standard?
Rick L.
PostPosted: Thu Nov 21, 2013 7:19 pm    Post subject: Re: 730 camshaft Reply to specific post Reply with quote
Effingham regrinding in Effingham,Il. (217-342-4186) ask for Dean. They built up my crankshaft and reground it and built up the fuel injector lobes on the cam and reground them as well.
