MF-65 tractor PTO Shaft Seal
Rkh
PostPosted: Mon Mar 18, 2013 3:29 pm    Post subject: MF-65 tractor PTO Shaft Seal Reply to specific post Reply with quote
I have a leak coming out of seal from rear pto. it looks like there is a bearing there but no seal. i ordered two different seals-1860325m1 & 1077452m1. both had to big of I.D. & O.D. to fit the 1 3/8" shaft. can you just put in a seal to go on the 1 3/8" spline shaftor do you have to tear bearing out of shaft?
samn40
PostPosted: Mon Mar 18, 2013 5:44 pm    Post subject: Re: MF-65 tractor PTO Shaft Seal Reply to specific post Reply with quote
You need to remove the shaft and bearing. It is quite easy. Drain the oil, remove the 3 bolts around the shaft retainer ring and remove the ring. put a PTO shaft off an implement on to your tractor shaft until it locks in place and then using a tyre lever or some other suitable lever just pry against the implement shaft levering against the transmission housing and the shaft will pop out. The seal is inside the bearing retainer and runs on a wider OD section of the shaft.
Sam
