What's going on with my drill ??
jCarroll
PostPosted: Wed Mar 20, 2013 4:09 pm    Post subject: What's going on with my drill ?? Reply to specific post Reply with quote
It's a DeWalt 14.4 volt cordless drill, model DW991.
Drill has worked flawlessly - until today the chuck shaft stopped turning. Wouldn't turn in either direction. In free air, the chuck would move a little, but had no torque whatsoever.
It was 35 degrees where I was working - a couple hours later I picked it up, and it had usual torque by holding the chuck. I did not test it by drilling or running some screws in.
What failed - healed - ???
Jim in MN
PostPosted: Wed Mar 20, 2013 4:44 pm    Post subject: Re: What's going on with my drill ?? Reply to specific post Reply with quote
Was it between high and low range?
Bret4207
PostPosted: Thu Mar 21, 2013 3:42 am    Post subject: Re: What's going on with my drill ?? Reply to specific post Reply with quote
Could be a bit of corrosion on the battery contacts. If it does it again give the battery a smack with your hand and see.
jCarroll
PostPosted: Thu Mar 21, 2013 4:54 am    Post subject: Re: What's going on with my drill ?? Reply to specific post Reply with quote
I didn't make an important point - the motor ran perfectly: fast, slow, frw or backwards - the chuck shaft didn't turn.
mkirsch
PostPosted: Thu Mar 21, 2013 5:41 am    Post subject: Re: What's going on with my drill ?? Reply to specific post Reply with quote
Then definitely it was either stuck between high and low range, or the torque release got gummed up with cold grease and stayed released.
DiyDave
PostPosted: Thu Mar 21, 2013 3:08 pm    Post subject: Re: What's going on with my drill ?? Reply to specific post Reply with quote
My ryobi did that once, I think the F/R switch was in the middle, IIRR
