setting govener on 60
53jd60
PostPosted: Thu Mar 21, 2013 4:57 pm    Post subject: setting govener on 60 Reply to specific post Reply with quote
How do you set the govener on a 60? throttle rod from carb to govener?
Pete in MD
PostPosted: Thu Mar 21, 2013 5:43 pm    Post subject: Re: setting govener on 60 Reply to specific post Reply with quote
With the throttle lever all the way forward and the carb throttle plate held wide open, the throttle rod should be a half a hole short of connecting to the throttle plate arm.
Ray Durham
PostPosted: Thu Mar 21, 2013 5:51 pm    Post subject: Re: setting govener on 60 Reply to specific post Reply with quote
Would this also be the same setting for a 1945 JD model A (hand Start)? Thanks
Pete in MD
PostPosted: Thu Mar 21, 2013 6:05 pm    Post subject: Re: setting govener on 60 Reply to specific post Reply with quote
Yes.
53jd60
PostPosted: Fri Mar 22, 2013 3:34 am    Post subject: Re: setting govener on 60 Reply to specific post Reply with quote
What about the adjustment for carb to govener?
Pete in MD
PostPosted: Fri Mar 22, 2013 7:03 am    Post subject: Re: setting govener on 60 Reply to specific post Reply with quote
I don't understand your question. You asked for the throttle rod (governor to carb) adjustment and that's what I gave you.
buck eye al
PostPosted: Fri Mar 22, 2013 2:16 pm    Post subject: Re: setting govener on 60 Reply to specific post Reply with quote
I beleive that "half the diameter short" adjustment is supposed to be checked at the governor end of the rod on the 50, 60 and 70.
Pete in MD
PostPosted: Fri Mar 22, 2013 7:40 pm    Post subject: Re: setting govener on 60 Reply to specific post Reply with quote
Think about it. It doesn't make any difference which end of the throttle rod is a half hole short.
