6329 motor
bradinpa
PostPosted: Thu Mar 21, 2013 5:43 pm    Post subject: 6329 motor Reply to specific post Reply with quote
Someone rebuilt this engine with a Deere kit and ran it for a half hour for the break in period. It started making noise so they shut it down. I took the engine apart and found number one piston hitting the head. The rod bushings are good and it plastiguage at .003. The piston measures .009 above the block and so does number six and that did not hit. Any suggestion why? This is in a straw chopper.
tim s
PostPosted: Thu Mar 21, 2013 5:47 pm    Post subject: Re: 6329 motor Reply to specific post Reply with quote
Maybe the wrist pin bushing split and it climbed on the other half???
tim s
PostPosted: Thu Mar 21, 2013 5:49 pm    Post subject: Re: 6329 motor Reply to specific post Reply with quote
Or a poor job on re-sizing the rod after new bushings were put in...
bradinpa
PostPosted: Thu Mar 21, 2013 6:04 pm    Post subject: Re: 6329 motor Reply to specific post Reply with quote
This motor was rebuilt because the guy said it smoked real bad but all it needed was an injection pump. It only has just over 3000 hours. The rod bushings were not replaced and they haven't spun. The holes line up with with the rod and bushing.
Kent Petersen
PostPosted: Fri Mar 22, 2013 3:57 am    Post subject: Re: 6329 motor Reply to specific post Reply with quote
didn,t deere use two differant thickness head gaskets fore this engine
Tx Jim
PostPosted: Fri Mar 22, 2013 5:24 am    Post subject: Re: 6329 motor Reply to specific post Reply with quote
I don't know the answer to different thickness of head gaskets but the gasket part #R114157 fit many,many models.
