1370 hydraulic drain plugs
PostPosted: Thu Mar 21, 2013 5:50 pm    Post subject: 1370 hydraulic drain plugs Reply to specific post Reply with quote
I would like to change the hydraulic oil in a 1370. Can someone tell me where the drain plugs are located. Thanks
PostPosted: Thu Mar 21, 2013 7:10 pm    Post subject: Re: 1370 hydraulic drain plugs Reply to specific post Reply with quote
There is one in front of the hyd. filters and of course a couple small pipe plugs for draining the oil in the filter cavity, The main plug is located in back right above the drawbar and in approx a ft from the back of PTO housing. You have to swing the drawbar out of the way, look under there and you will see it.
