3020 power steering issues
antique_jdfan
PostPosted: Fri Mar 22, 2013 8:48 am    Post subject: 3020 power steering issues Reply to specific post Reply with quote
I have a John Deere 3020 that has some steering problems. When operating the steering wheel right, it will "lock" while turning, then if you hold a little pressure to the right the wheels will slowly creep all the way to that direction. After they turn all the way to the right it will operate properly for a few minutes and then it will do the same thing. Sorry for the rambling but I hope this illustrates the problem I am having. I have been told it is likely a steering valve problem. Any feedback would be appreciated, also I understand that Tim S rebuilds these and I would like to contact him.
tim s
PostPosted: Fri Mar 22, 2013 9:05 am    Post subject: Re: 3020 power steering issues Reply to specific post Reply with quote
There is a strong chance that it is the steering "Motor" down front, the o-rings are worn and most likely the original ones. They will leak to the other side of the piston, the the valve will dead head against it for a bit till the piston re-fills,,then it will all happen again. Yes I do rebuild these steer valves and bench test them to prove they are set correctly,,the tough thing is they are not handy to ship...
antique_jdfan
PostPosted: Fri Mar 22, 2013 10:14 am    Post subject: Re: 3020 power steering issues Reply to specific post Reply with quote
Would you mind if I called you and discussed this in more detail?
tim s
PostPosted: Fri Mar 22, 2013 10:46 am    Post subject: Re: 3020 power steering issues Reply to specific post Reply with quote
Sure give me a call 740-743-1085
Tx Jim
PostPosted: Fri Mar 22, 2013 11:39 am    Post subject: Re: 3020 power steering issues Reply to specific post Reply with quote
Here's a parts schematic & parts list of the steering motor.
2-B3685R PACKING,O RING View/Update 3.46 USD 6.92 USD
1-R26282 PACKING O RING View/Update 2.63 USD
1-R26290 RING,BACK-UP View/Update 5.04 USD
2-R47083 RING,BACK-UP View/Update 3.79 USD 7.58 USD
1-R34748 SEAL,OIL ADD 30.28 USD 30.28 USD
Parts that have an issue will display a flag. *Subtotal 52.45 USD
