McCormick International Brush Cutter Maybe Mobel 410 Help ID
KRS_MED
PostPosted: Fri Mar 22, 2013 4:26 pm    Post subject: McCormick International Brush Cutter Maybe Mobel 410 Help ID Reply to specific post Reply with quote
Was left a four foot brush cutter by father in law. It been sitting around and I haven't thought much about it. Now i want to get it going. May not be any thing wrong with it. Anyway its very heavy made of 1/4" plus diamond thread metal. It's original not a repair unless that were very very good. It has two trailing wheels. He had a 140 so at some time someone did a hack job welding up a one point hitch. It has a flat slip clutch withe the springs on the PTO shaft that's just straight bar type (not sure how to describe it). The drive line has a metal square box over the shaft when it leaves the gear box. I know this is not a lot of info but i can't find any ID numbers and decals aren't readable. It looks a lot like the Model 410 except that its squared off on the rear and front. Both are open without any chain or other guards. Even a guess would help so I could look it up. Thanks for the help, and the vague info I have.
I would guess its from the 60's.
Thanks,
Keith
jon f mn
PostPosted: Fri Mar 22, 2013 6:29 pm    Post subject: Re: McCormick International Brush Cutter Maybe Mobel 410 Hel Reply to specific post Reply with quote
A picture will be the only way to help with that. It
could be any of a dozen or so with that info.
View user's profile AIM Address
Case Nutty 1660
PostPosted: Fri Mar 22, 2013 8:29 pm    Post subject: Re: McCormick International Brush Cutter Maybe Mobel 410 Hel Reply to specific post Reply with quote
this is a IH unit I have not sure if it is like what you have, mine is different than a regular "bush hog" style mower as it has a staionary knife the rotating ones pass through I call it a "shredder"
Ol' Gimpy
PostPosted: Sat Mar 23, 2013 6:28 pm    Post subject: Re: McCormick International Brush Cutter Maybe Mobel 410 Hel Reply to specific post Reply with quote
I guess would be a #25 or 26,but a picture would be a clincher.
KRS_MED
PostPosted: Sun Mar 24, 2013 8:02 am    Post subject: Re: McCormick International Brush Cutter Maybe Mobel 410 Hel Reply to specific post Reply with quote
Its not like any of the pictures. It has two trailing wheels like a normal rotary cutter, and it made out of diamond plated metal. Ill try and get a picture its raining to day so it may be tomorrow. Thanks for the help also!
Keith
Freedom Lake Farm
PostPosted: Wed Sep 18, 2013 9:53 am    Post subject: Re: McCormick International Brush Cutter Maybe Mobel 410 Hel Reply to specific post Reply with quote
I saw your photos. I have a similar machine. Any ideas on stopping a leak of gear lube from the gear box? Probably no gaskets available. I tightened the bolts that were loose on the bottom but it still leaks.
Great photos. Lloyd Wilson Freedom Lake Farm
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
