1855 turbo lube lines?
Adam Suess
PostPosted: Sat Mar 23, 2013 12:09 pm    Post subject: 1855 turbo lube lines? Reply to specific post Reply with quote
I'm putting together a 1855 and discovered that this engine has bigger oil supply line for the turbo. Most of my other 310T's have a smaller line. I cannot find the bigger line in the parts book and I need new rubber feral (sp) for the compression fittings. Any one know the part # for the rubber feral? Also when did they go to bigger lines? I also have a parts engine that has the bigger line and also a far bigger turbo return line along with a bigger hole in the timing gear cover. Is this some sort of a update?
J. schwiebert
PostPosted: Sat Mar 23, 2013 3:29 pm    Post subject: Re: 1855 turbo lube lines? Reply to specific post Reply with quote
You need to find a copy of that service bulletin that explained all that. That was probably 35+ years ago.
