Oliver 1955 D
Rusty Knuckles
PostPosted: Sat Mar 23, 2013 2:46 pm    Post subject: Oliver 1955 D Reply to specific post Reply with quote
So what are some of the pro"s and con"s on the Oliver 1955. I am thinking about picking one up and would like a little incite. How good are the engines, how long before they need a rebuild? How long are the turbos goo for? Any trans problems.
jordan hackman
PostPosted: Sat Mar 23, 2013 3:41 pm    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
the fact that you are asking about a 1955 means you are new to oliver. these tractors are kind of the black sheep of olivers. yes they have decent power, around 120. yet the motor on these are not that reliable. oliver put more power in the moter than it could handle. it is notorious for blowing the motor and throwing a rod, many owners convert to cummins. still with a lot of care and attention you can use the original motor.
Thompson Mike
PostPosted: Sat Mar 23, 2013 3:47 pm    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
If the motor has been rebuilt with the updates you should be fine. If it has never been worked on. Use caution. I have an 1855 and love it
G1355
PostPosted: Sat Mar 23, 2013 6:59 pm    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
Like said motors are known for trouble, someone must of put a turbo on, think the only oliver that had a factory turbo was a 1950t. Rather than the motor think the rest of the tractor is good, I like the over/under and there rear end is pretty good also.
OLWHDA
PostPosted: Sat Mar 23, 2013 7:25 pm    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
1855 and 1955 came from factory with Turbo.
G1355
PostPosted: Sat Mar 23, 2013 7:53 pm    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
Oh, never knew that, thought only the 1950t did, guess never owned a 1855 or 1955 or ever really been around one, ran a 1655, 1755 and 2255 before, guess you learn something new every day,
G1355
PostPosted: Sat Mar 23, 2013 7:56 pm    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
Just went and looked at my oliver brochures you are right, should of looked in them first, never nought they were though,
Don-Wi
PostPosted: Sat Mar 23, 2013 8:05 pm    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
Yup, we've got an 1855. Never checked the serial number to see what year it is, but it's a later model. Puts out 105 HP on the dyno, and I love to hear that turbo. We just had the engine worked on a few years ago. The wrist pin bushings went out and we found out the prev. owner did a 1/2assed job during the overhaul, mixing bolts etc... Had 1 bad rod and it needed all new bearings, wrist pins, bushings, etc... and it was good to go again.
Donovan from Wisconsin
DBAF
PostPosted: Sun Mar 24, 2013 4:38 am    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
Some days I wish I had it back.
Eric The Red
PostPosted: Sun Mar 24, 2013 5:58 am    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
If the Engine is rebuilt right, It is the sweetest sounding engine on the planet.
CumminsMan
PostPosted: Sun Mar 24, 2013 7:56 am    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
The 1955 didn't have the motor troubles that plagued the 1855, thanks to an oil cooler. One of the best of the 55 series, and very fuel efficient. No transmission problems, and if worried about condition of Turbo, I'd advise you take off the intake hose on turbo and see if you can find any oil residue.
Rusty Knuckles
PostPosted: Sun Mar 24, 2013 5:57 pm    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
Are these motor update still available? And is there anything from the outside of engine that would give it away?
Not new to the Oliver's we have 18 of them just new to the 1955. Just looking to step up a little.
chucksoliver77
PostPosted: Sun Mar 24, 2013 6:26 pm    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
Rusty Knuckles wrote:
(quoted from post at 06:57:36 03/25/13) Are these motor update still available? And is there anything from the outside of engine that would give it away?
you can look in the dipstick hole and see if it has the 12 point rod bolts. they are the good ones, Chuck
formenwhogrow
PostPosted: Mon Mar 25, 2013 7:27 am    Post subject: Re: Oliver 1955 D Reply to specific post Reply with quote
Pros: 3-speed, good rearend and brakes, decent hydraulics, fuel efficiency, sounds awesome (if you"re into that sort of thing).
Cons: 310 waukeshua turbo-diesel Sad However, as others have said, the 1955 had an oil cooler on it which helped with it"s reputation. As you probably know, this engine is costly to rebuild and if it has had work done recently, be sure a reputable person did it!
