Offset keys
Inquiring Minds
PostPosted: Mon Mar 25, 2013 8:53 am    Post subject: Offset keys Reply to specific post Reply with quote
Who makes offset keys for cams?
Farmall47
PostPosted: Mon Mar 25, 2013 10:44 am    Post subject: Re: Offset keys Reply to specific post Reply with quote
Summit and Jegs sell some but for tractors the may be too small. several engine builders grind them as the need them.
Inquiring Minds
PostPosted: Mon Mar 25, 2013 10:49 am    Post subject: Re: Offset keys Reply to specific post Reply with quote
Let me update this post: I need a 6 degree offset key for the cam. this is for a c 169 farmall in a 300 u. the key is .25" thick.
Thank you...
Slow burn
PostPosted: Mon Mar 25, 2013 12:37 pm    Post subject: Re: Offset keys Reply to specific post Reply with quote
Call Gary Baker. He will set you right up.
Tim Yates
PostPosted: Mon Mar 25, 2013 2:33 pm    Post subject: Re: Offset keys Reply to specific post Reply with quote
.005" is equal to 1 degree on the farmall.I have some already cut , will check to see what I have.
Inquiring Minds
PostPosted: Mon Mar 25, 2013 4:50 pm    Post subject: Re: Offset keys Reply to specific post Reply with quote
Thanks Tim,Let me know what you have.
Builder
PostPosted: Mon Mar 25, 2013 8:55 pm    Post subject: Re: Offset keys Reply to specific post Reply with quote
Bosch has some common sizes in stock. They are meant for pump timing on a diesel, but sometimes they fit a tractor cam.
Other than that buy a thicker key than what you need from McMaster Carr and then have it milled to your specs. Trigonometry formulas can be found all over the web.
Good Luck!
Tim Yates
PostPosted: Wed Mar 27, 2013 4:24 pm    Post subject: Re: Offset keys Reply to specific post Reply with quote
I only had 2 left. One was .005 and the other was .003. I don't think either will help. The .005 will only get 1 degree.
Inquiring Minds
PostPosted: Thu Mar 28, 2013 5:47 pm    Post subject: Re: Offset keys Reply to specific post Reply with quote
thanks for looking.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
