Fast hitch disc plow application?
Al Wilson
PostPosted: Mon Mar 25, 2013 2:55 pm    Post subject: Fast hitch disc plow application? Reply to specific post Reply with quote
I have an International 300 Utility with a fast hitch. I found a two bottom fast hitch disc plow local with small fast hitch points. If I add the 1/2" spacer to the fast hitch points, will that plow work OK with my 300U? I just need to plow a small garden.
wolfman
PostPosted: Mon Mar 25, 2013 4:50 pm    Post subject: Re: Fast hitch disc plow application? Reply to specific post Reply with quote
Should work.
wijim
PostPosted: Mon Mar 25, 2013 6:24 pm    Post subject: Re: Fast hitch disc plow application? Reply to specific post Reply with quote
My 350U has the factory spacers for that reason. Jim
Al Wilson
PostPosted: Mon Mar 25, 2013 6:31 pm    Post subject: Re: Fast hitch disc plow application? Reply to specific post Reply with quote
>My 350U has the factory spacers for that >reason. Jim
Do these stay attached?
Thanks, looks like I'm set (if I can strike a deal).
Dean Olson
PostPosted: Sat Mar 30, 2013 5:19 pm    Post subject: Re: Fast hitch disc plow application? Reply to specific post Reply with quote
It will "work". That plow was designed to go behind a Farmall Super C that you could easily adjust the wheels to the proper width.
That would be the only possible issue is getting your wheels set narrow enough.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
