will jd 350 tracks interchange with 440 crawler
Jona Horsley
PostPosted: Mon Mar 25, 2013 7:28 pm    Post subject: will jd 350 tracks interchange with 440 crawler Reply to specific post Reply with quote
does anyone know if john deere 350 tracks will interchange with a john deere 440ic?
shinnery
PostPosted: Mon Mar 25, 2013 11:16 pm    Post subject: Re: will jd 350 tracks interchange with 440 crawler Reply to specific post Reply with quote
I understand that the pitch is the same but 440I bushings are smaller in diameter than 350 bushings so you have to use 440I sprockets with 440I rails.
You might try asking at jdcrawlers dot com.
Bryce
Newton Miller
PostPosted: Tue Mar 26, 2013 2:50 am    Post subject: Re: will jd 350 tracks interchange with 440 crawler Reply to specific post Reply with quote
you can have a 350 rim welded on the 440 sprocket then the 350 chains run fine. I have done it several times.
Bret4207
PostPosted: Tue Mar 26, 2013 3:39 am    Post subject: Re: will jd 350 tracks interchange with 440 crawler Reply to specific post Reply with quote
Lets put it this way, they'll fit fine if things are worn out enough. There's a right way to do it and a not so right way. The not so right way works for me, but then, I'm a cheapskate.
