case 400 diseal buying?
daynee
PostPosted: Tue Mar 26, 2013 7:55 pm    Post subject: case 400 diseal buying? Reply to specific post Reply with quote
Im looking at a case 400 what should I look out for? The guy want s 1500 is it worth that? Dont have a picture but I can tell you it has a loader wih bucket and the fenders which covers the whole back tire.
Daynee
caseman-d
PostPosted: Tue Mar 26, 2013 8:09 pm    Post subject: Re: case 400 diseal buying? Reply to specific post Reply with quote
From the information you gave it should be a steal at that price.
caseman-d
chuck machinist
PostPosted: Wed Mar 27, 2013 12:44 am    Post subject: Re: case 400 diseal buying? Reply to specific post Reply with quote
I would take a drain plug sample from the motor,tranny,and pto reservoir,and look for moisture content,I removed the oilbath cap on the intake filter and found a dead mouse!Pull the valvecover caps and see if the they are reasonably clean,Coolant in your motor oil sample? These are just some of the things I checked,and then I based my offer accordingly.Good Luck Chuck
tomturkey
PostPosted: Wed Mar 27, 2013 3:02 am    Post subject: Re: case 400 diseal buying? Reply to specific post Reply with quote
if it starts and runs its worth that. imo, if it won't start you are buying a project you decide. gobble
Doc Larry
PostPosted: Wed Mar 27, 2013 3:12 am    Post subject: Re: case 400 diseal buying? Reply to specific post Reply with quote
If the tires are good and it runs smooth, good oil pressure, probably okay if it's a nice loader. If it needs tires, or if it needs any serious work, too much. Just my opinion. Prices vary from region to region. It costs a small fortune to haul tractors around nowadays....
Don Rudolph
PostPosted: Wed Mar 27, 2013 8:41 am    Post subject: Re: case 400 diseal buying? Reply to specific post Reply with quote
How are the tires? New tires could cost a bundle these days. If it has a loader, was it used as a loader tractor or just for goofing off? Loaders are hard on front ends so if it was used hard the steering system could be worn out. Look for slop in the transmission gears. Check all fluids as others have mentioned. If it has a loader chances are pretty good that the rear tires will be loaded with weight solution. Check the rims to see if they are sound and not rusted out. If it is in good shape after checking all that out 1500 is cheap. If some of these things are bad be prepared to spend a lot more fixing it up. Don
C. Amick
PostPosted: Wed Mar 27, 2013 5:31 pm    Post subject: Re: case 400 diseal buying? Reply to specific post Reply with quote
Fenders cover the whole back tires? Could it be an orchard model? Do you have the serial number?
